Question about HP Computers & Internet
C drive showing 84gb capacity it should be 840gb
  • HP Master
  • 27,725 Answers
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
click start control panel administrive tools,computer management ,disk management right click on your drive scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 21, 2011
Toshiba hddr160E03X hard drive showing full capacity at 147GB
Manufacturers rate the capacity of their hard drives in an unformatted state. When you format a hard drive the actual capacity drops approx. 10% and in this case it leaves you with 147Gb capacity.
Feb 06, 2012 | Computers & Internet
When i insert the memory card, it is not showing on my phone. but if i insert the memory card in some other phone then it shows. Kindly help??
Your phone may simply not be compatible with cards of that capacity. Try a smaller capacity memory card, or check your user manual for memory card restrictions / maximum capacity.
Jun 20, 2011 | SanDisk 2GB microSD Memory Card
MY WD500H1U-00 SHOWS UP AS A 5GB DRIVE
Follow these steps:
1. Download HDD Capacity Restore Tool.
2. Install and Run
3. Select your Western Digital drive and hit Restore Capacity.
that's it.
If this fails to restore the capacity it probably because your hdd has a firmware issue. If such is the case then you need to send the drive to a data recovery office, or to Western Digital Shop.
Hope this helps.
May 06, 2011 | Computers & Internet
My HDDR500E03A 500 GB is only showing 3.98 GB on total memory, what happened to the rest?
The 3.98 GB you are seeing is probably your total RAM memory and not the storage capacity of the hard drive. RAM memory is completely unrelated to the hard drive capacities.
Double click on the MY COMPUTER icon.
You should then see all the disks and drives that are currently connected to your computer. Your USB hard drive should be one of the drives listed there.
Right click on each of them and select PROPERTIES from the menu shown. This will show you the storage capacity of each drive including how much space is used and how much is free (empty).
Good luck.
Mar 15, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
WD MyBook Premium not showing any capacity using Firewire
There seems to be a firewire port issue on the device. Why not leave it USB?
Jun 05, 2009 | Western Digital My Book Essential Edition...
My flash drive capacity shows 0bytes on the free space, and 0bytes on the used space.
  1. just go to my computer right click on it go to ' manage' > disk management > right click > on your pen drive allocation > partion then you can format it and you can get your memry back thanks
Jul 10, 2008 | Electronics - Others
Problem in pen drive/mp3 player capacity
when you hook it up to the puter, go into My computer right click on the removable drive then click on explore disc and see what oter types of files are taking up the extra memory as if there are none then the drive has bad memory cells.
Apr 28, 2006 | Sony NW-E405 MP3 Player
Computers & Internet Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
