Question about Bosch BOS18946 9" Large Angle Grinder
Everytime i turn on the grinder it sounds under pressure and then blows the fuse.any idea
    Sergeant:
  • 259 Answers
It sounds like the motor is drawing too much current and is burned out.
Posted on Mar 21, 2011
Grinder does not work, keeps blowing fuses! Can I fix it?
You need to return it for repair or buy a new one.
Nov 24, 2015 | Saeco VIA Veneto Combi
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
I keep blowing a turn signal fuse on my 03 f350, why???
A mechanic would disconnect the turn signal switch and check the circuits for shorts to ground.
Jul 15, 2012 | 2003 Ford F350 Super Duty DRW SuperCab
Everytime i switch on my 6.80 pressure washer the fuse blows on the machine
This sounds like the bypass (unloader) valve is sticking and the internal switch it activates is being held in a half open position. This will blow a fuse. It could also be loose wiring inside. If you ran it with an extension cord you may have weakened the fuse. Sorry, I cannot find a schematic anywhere. I think it is European, correct?
Aug 21, 2009 | Alfred Karcher Pressure Washer
Stalled... won't grind... makes no sound... it is 5 years old...
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
May 21, 2009 | Solis Maestro G385 Electric Burr Grinder
Non-working Starbuck's Barista burr grinder.
Hi
Remove bean hopper
Insert a screw driver into the **** and pry gently outward with a
The thermal fuse is to protect the motor its a 104C
May 12, 2009 | Starbucks Barista Burr Grinder
Gauges blow fuses,brake and turn signal lights dont work
all my gauges quit working and my turnsignals checked all my fuses under the hood and dash whats my problem?
Mar 11, 2009 | 1994 Chevrolet Suburban
My tail lights and dash lights dont work
it sounds like a bad switch if the fuse blows when you turn the lights on
Jan 07, 2009 | 1992 GMC Yukon
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Bosch BOS18946 9" Large Angle Grinder Logo
114 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
