Question about Acer Aspire 5500 5570-2609 Laptop
Laptop won't turn on
My husband was surfing and the laptop went out. Haven't been able to turn it on. When we attempt to turn it on the battery light flashes (yellow) a couple of times and goes back out. Power light does the same thing (yellow)???
  • cecaptain Aug 04, 2008
    I got an IBM laptop pII doesn`t accept any order,no windows,no set up page...it seems to be locked,,,thanx
    Sergeant:
    Champion:
  • 256 Answers
Hi
Check power cable and the adapter....
Thanks
Posted on Aug 03, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My laptop won't hold a charge. have a new battery
Is the battery a genuine Dell battery? 3rd party batteries can be high quality or crap, just depends on the maker. Regardless, when you attempt to charge it, does it at least take a charge even though it won\'t hold it? Or does the battery refuse to accept a charge at all? When you plug in your laptop, does the charge light come on? Does the the battery level icon on the lower-right corner of the screen show it\'s plugged in? I know, lots of questions.
Sep 06, 2014 | Dell Inspiron 1420 Laptop
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Sep 10, 2011 | Acer Aspire 5732Z-4855 Notebook
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
Help me to unlock a laptop keyboard
I had the same problem for my laptop as well. I basically turned it off and removed the battery for ten minutes, then put it back in and turned it on to which it started working. I don't know why it stopped working before or started to work again when I removed the battery but it's happened three times and everytime that has always worked for me. I know it's not very technical but try it.
Jul 02, 2008 | Toshiba Satellite A105 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
