Question about Whirlpool GEW9250 Electric Dryer
Please help...i have a brand new whirlpool dryer mod #wed9450wwh and it takes forever to dry a load of clothes...a small load or a large load. i have tried every setting and bought a new dryer vent....whats wrong? jackie
  • Whirlpool Master
  • 2,699 Answers
If the heat is working correctly on the dryer then you have lint blocking the air movement in the dryer.if the vent line is long from the back of the dryer to the outside duct,remove the vent line from the back of the dryer,go outside and make sure nothing is blocking the outside duct like a cage or screen,if there is remove it.then go back inside i use a leaf blower to blow out the line,i've seen bird nests blow out of the vent line.also unplug the dryer,remove the lint filter,remove the bottom panel then remove the duct that the filter slides into and clean that out.if this isn't the problem then check to make sure the heat is working correctly,but it sounds like there's a block in the line somewhere.
Posted on Mar 21, 2011
    Champion:
  • 239 Answers
Check the vent cap on the outside of your home to see what the air flow is like when the machine is on. It should be forceful enough to blow your haire back if you were to put your face in front of it. Make sure the vent hose behind the dryer is as short as possible and is not pinched or coiled. This definitely sounds like an air flow issue.
Kelly
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
It takes forever to dry clothes (on Medium Heat Setting). For small loads (4-5 articles of clothing) it takes 2+ hours to dry, and even then it's slightly damp and cold when I remove it from the...
sdf
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
so clean your vents and filter forst
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 24, 2010 | Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer takes forever to dry clothes
Check out this tip... it will help you to find out what is making it take so long..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Maytag PYE2300AY Electric Dryer
Whirlpool gas dryer not hot enough .With small or large loads its taking over an hour to dry. Is there coils I can check?? Not sure what to do
This sounds like dryer vent has to much lint in it. It needs to be cleaned all the wall to outside of house. It will hold moisture in and not let clothes dry..
Jun 17, 2009 | Dryers
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
Water comes into machine when on dryer clothes tak forever to dry
This machine drys by intermittently spraying a mist of cold water into the warm, moisture laden air traveling in the tube at the back right side of the machine. The cooling of that air stream causes moisture to condense and join the added water, which is periodically pumped out the drain. It takes a long time, and the clothes are not as "dry" as you may be use to with a conventional dryer. Never try to dry more than a half tub of laundry. These machines are great if you have small amounts of laundry to do, have limited space, and / or do not have 240 volts, (or a gas supply) and cannot do an outside vent. Don't plan on doing more than two loads per day. (one in AM, one in PM) Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Jan 17, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
