Question about Cell Phones
My cell phone says its charging all night, however when I unplug the charger it says I only have one bar of battery and it dies soon after.
  • 33 Answers
That mean the the battery in your cell phone is dying, you will need to by a new battery for it, many are available online for pretty cheap. just search for "your phone name and battery"
Posted on Mar 21, 2011
Tip
Will this work on a samsung Myshot II phone I have cricket service and my phone...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Mar 15, 2010 | T-Mobile MDA
My phone will charge but as soon as I unplug it, it dies
did you check the battery , is it bulged? if it is bulged kindly change the battery
Feb 13, 2010 | LG CHOCOLATE VX8500 Cellular Phone
My razr will not hold a charge. Changed the battery,helped a little while but now it is doing the same thing.Dies constantly.
The charger is bad, not supplying enough current to bring the battery to full charge.
Or your replacement battery is bad.
There is a small possibility that the charging circuit inside the phone is bad.
So, before you spend money on a charger, see if someone will lend you their charger and let the phone charge over night. If it holds a charge then you know the charger is bad.
Good Luck!
Jan 03, 2010 | Motorola Mobility RAZR V3
Lg ks360 battery problem,, charge it up fully and battery dies in 2 hours my phone is dead in the morning when i left it the night before with only one bar of the battery down. What can i do to solve this...
Im not sure if this goes for phones...
But I noticed that when you get something with a charger and you seem to over-charge it (Leaving it constantly plugged in or charging it for long periods of time after its fully charged) it actually makes the life of the object shorter....
It could be that because you've been leaving it over night to charge its been eating at the LGs battery...
But like I said, im not sure...
Obviously you can't fix something like that...
Jun 02, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Kyocera Candid 2 phone won't hold charge
Sounds like you need a new phone, that brand wasn't meant to last long, it more or less is a starter phone made to be upgraded.
Never had any problems with your carrier, but have had several problems with that brand of phone
Apr 04, 2017 | Kyocera Candid KX16 Cellular Phone
My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Oct 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
IT KEEPS TURNING OFF WHEN I PLUF THE USB IN THE COMPUTER AND WHEN IT CHARGERS,FULL BATTERY,IT DIES OUT QUIKC
i guess theres a problem with the board of your cellphone,there might be some components that has been shorted out and thats the reason why it drains battery so fast and it shutsdown upon connecting to the usb
Jul 17, 2008 | Samsung Cell Phones
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
