Question about Canon Cameras
I rotated some pictures in my computer and was saving them.but now when I turn on my camara it says file error.why? Do I still have the pictures?
  • 72 Answers
You should still have the photos if you access the card through a USB card reader. By rotating the photos, you have technically changed the photo x by y resolution to y by x resolution and so the camera cannot read the file.
Posted on Mar 21, 2011
    Brigadier General:
  • 11,967 Answers
You cannot work on your pics using your computer and then expect your camera to recognize the changes made by a different operating system than its own. Use your computer to download all the pics (use a card reader if necessary). Once they are safely on your computer, format the card in your camera and vow never to do that again. If you want to rotate pics in the future, download them first and leave the ones on the card alone.
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
I took the memory stick out of the camara and plugged it into a card reader for the computer. When I put it back in the camara some of the pictures were corrupted (file error). How do I get the pictures...
one suggestion is if they are still on the card,load them into your computer then open with a picture editing software and save them back to the card as a jpeg image.i have found this to work for me in many cases.hope this helps.
Jan 01, 2011 | Sony Cameras
Rotating images
You will have to download them to your computer, and then use software to rotate the pictures and resave them. A free, good program to do that is called Irfanview, just google it and you will find a site to download it from. The software allows you to adjust brightness, colors, rotate the pictures, and many options normally associated with a high-end product like PhotoShop, etc. When you rotate the pictures in Irfanview, you just pick "File", then "Save", and the picture will be saved in the present rotation. There may be software options on the camera to do this, but there usually isn't on most cameras and camcorders. Not having owned a Flip Video, I couldn't say for sure, but my bet is that it won't do it, and you will have to manipulate the pictures through computer software such as Irfanview or another viewer inherent on your computer.
Jun 06, 2010 | Pure Digital Flip Video Ultra Camcorder
No picture with videos
If you are using HDMI cables shouldn't happen. Can you see the picture for the videos on the camera screen? Check the connection and setup on the computer for videos. Make sure your computer supports the kind of videos you are shootiong at the speed it loads on the computer. Trying saving the files on the computer hard drive and then watching it from the computer.
Feb 19, 2010 | DXG Technology DXG-572V Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Paint cannot save file windows 2000 proffessional
This fix should allow you to use MS Paint to Open and Save JPG files, and Open and Save GIF files. The quality of the saved GIF with MS Paint may be reduced because of the limited 256-color palette (See here for an explanation and workaround). A better alternative for opening and saving JPG and GIF files would be to download and install a great FREE image viewer called IrfanView (MS Paint is still better for individual pixel editing, so it's good to have both).
If you want to proceed with the MS Paint Fix, you should first do a search on your hard drive to see if you
have the jpegim32.flt and gifimp32.flt filters.
You can find those files here:
http://www3.sympatico.ca/one.human/files/Jpegim32.flt
http://www3.sympatico.ca/one.human/files/Gifimp32.flt
You need to make sure you have both filters in the following folders:
C:\Program Files\Common Files\Microsoft Shared\grphflt
C:\Windows\MsApps\Grphflt
You may already have the JPEG Filter on your system, but only in one location. If that is the case, Copy and Paste it to the other location. Once you have the JPEG Filter in both locations, you may only need to do a simple Registry edit to be able to "Save As" a JPG.
If you already have the JPEG Graphics Filter on your system (and in both locations as stated above), but MS Paint still won't let you "Save As" JPG, you can manually edit the Registry to correct this. It's a simple fix. Go to Start, Run, type REGEDIT, and click OK. Go to this key by clicking the + signs beside the keys (folders):
HKEY_LOCAL_MACHINE\Software\Microsoft\Shared Tools\Graphics Filters\Export\JPEG.
Click on the "JPEG" key (folder) in the left pane, and you'll see a String Value in the right pane with the name "Extensions". Make sure under the "Data" column it shows only "jpg". If it shows "jpg, jpeg", double-click on the "Extensions" string and from the "Value data" field remove "jpeg" so that it only reads "jpg" (without the quotes).
If it worked, this edit allows you to "Save As" JPG. If it didn't work, or if you want to be able to also open and save GIF files, read on.
Or use this reg file to export your files as jpeg
http://www3.sympatico.ca/one.human/files/Filter_JPEG_Export.reg
Jul 29, 2009 | Intel Pentium III, 1.13 GHz...
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Copied files disappeared as soon as they were copied over
Did you try to copy one picture file to your mini harddrive then change it properties to archieve only? After that you can rotate it freely without that annoying message.
If that does not go as expected. Could be virus infection. Both your miniharddrive and your computer is infected. Some do it by changing it properties to read only then hide it.
You should first start disinfecting. The files can be view by clicking tools in My computer then set to view hidden files then start exploring your minihard drive. Some infection only affects picture files.
Just for the thought.
Apr 13, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
Feb 11, 2009 | Canon iR 2016i Black and White Copier
File Error
my camara when I see or viewed the picture same of they are bad with lines and same videos says error and I can't see it
May 18, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
