Question about HP Office Equipment & Supplies
My hp j4680 keeps printing skewed iv tried sorting out the paper stack and tray to no prevail. iv also tried aligning the printer but where the alignment page is printed skewed the scanner keeps reverting to the alignment default settings HELP
SOURCE: Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
Posted on Jul 10, 2008
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
SOURCE: HP psc 2110 Printer keeps
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
Posted on Jan 28, 2009
petree69
  • 4 Answers
SOURCE: my printer will not align the print cartridges
Okay i used to have the same problem, but all you have to do is this:
1.  Plug in HP PSC 2110xi All-in-One to the computer 2.  Turn the printer on 3.  Unplug the power chord from the printer (don't turn it off before you do this) 4.  Wait at least 45 seconds (and actually wait 45 seconds, don't guess) 5.  Plug the printer power chord back into the outlet 6.  If the printer does not automatically turn on, turn it on 7.  When it asks you to align cartridges, press enter, and follow the directions
This time it should work :]
Posted on Feb 12, 2009
  • 240 Answers
SOURCE: HP 2210 New Black Ink Cartridge print alignment page over & over.
unplug the printer while it is in ON state..it will reset all settings..^_^
Posted on May 16, 2009
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
Alignment is off on all my copies, it's not the computer
The two (or 3) wheels that "pull" the paper into the paper are not working "together".
Thus, the paper is "skewed" when it is passing under the ink-jets.
Take the printer to a qualified technician, to check those rollers.
Mar 17, 2011 | HP J4680 Office Jet All-In-One Printer
How can i prevent paper jams
ø Remove printer paper from its original packaging. Insert all unused paper into a large, resealable bag. Store the bag with the unused paper on a hard, flat surface away from extremes of heat and humidity to prevent curling, bending, ripping and wrinkles which can cause paper jams.
?? Remove only the amount of paper you need for a particular job from the resealable bag. Tap the paper stack on a hard flat surface to align the edges. Check the paper for rips, curls, wrinkles or bent edges. Remove and discard any unsatisfactory pages.
?? Insure all paper in the stack is the same size and type. Insure only paper types recommended for the HP All-in-One printer is being used. Recommended paper types can be found online at www.hp.com/support/inkjet_media.
?? Insure the HP Officejet All-in-one printer is not currently servicing a print job. Remove any original papers from the copier glass.
?? Insert the stack of paper into the input tray, short edge forward. Slide the stack forward until it stops. Do not force the stack beyond its initial stopping point.
?? Slide the paper width guide inward until the paper is held snugly in the input tray, but not so tightly that it bends the paper. Insure the stack of paper does not extend
?? Observe the printer during operation. Promptly remove printed pages from the output tray.
Dec 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
When i give print command the paper was jammed in printer.
The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
Also go to this link to do a Printer Cleaning
Dec 03, 2010 | HP LaserJet 1020 Printer
How do i align head on printer
Hi Good day!! To Align read this
1. Raise the input tray, which you may fold over the top for compact storage. Lower the output tray at the bottom.
2. Slide the "paper-width guide" on the input tray to the left. This is the small, adjustable tab situated where you will place the stack of paper.
3. Load a small stack of paper into the input tray. Make sure short side is forward and the print side is up. For some paper, it makes no difference which side is up. Slide the stack down until it stops.
4. Slide the paper-width guide to the right, snug up against the stack of paper to ensure proper alignment.
Method 2:
1. click start
2. click printer and faxes
3. right click your installed printer and then properties
4. click printing preferences
5. click maintenance tab
there you should see alignment option click it
Thank you for using FixYa
Nov 19, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I am trying to print envelopes using HP Officejet Pro 8000. I don't see an envelope guide and the envelopes are skewing when feeding. Is there an easy solution here?
If the tray is similar to a Officejet PRO 8000 that I have,REMOVE the stack of paper, bring the adjustable guide walls towards the center, and you should be able to print envelopes.
Oct 30, 2009 | Office Equipment & Supplies
HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
Dec 15, 2008 | HP LaserJet 3050 All-In-One Printer
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's...
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Apr 11, 2008 | Office Equipment & Supplies
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
