Question about Car Audio & Video
1998 nissan 200sx with cy516 radio/cd player. radio works but no sound from cd player
SOURCE: '06 Nissan Murano factory radio/cd player removal steps
what holds the radio in place besides the 2 side screws in a 2006 nissan murano
Posted on Feb 08, 2009
  • 81 Answers
SOURCE: 1998 nissan 200sx 1.6l car wont start has fuel and fire
what you need to check is are you getting any spark at the spark plugs, to do this, unplug one of your spark plug wires at the spark plug, find a screwdriver that will fit inside the spark plug wire housing, make sure your screwdriver has a insulated or non conductive handle, hold the steel shank of the screwdriver about 1/8"-1/4" from your exhaust manifold and have someone crank the engine, just for a second or two, look to see if there is spark jumping from the screwdriver shank to the manifold, if there is, then you eclectically is probably OK.
second you need to check your fuel, you really should have a fuel pressure gage but for now lets just do a preliminary check.
find your fuel line going to the intake manifold (steel tubing 5/16"-3/8" diameter) you need to disconnect the line somewhere between the fuel pump and the intake manifold. you'll need a can.
hold the can under the fuel line so fuel doesn't go everywhere, then have someone crank the engine, if it is an electric fuel pump you wont need any help, all you'll need to do is turn the key on and it should start pumping fuel, the fuel discharge should be very noticeable, it will really start coming out fast and furious.
If you don't have fuel coming from the line or very little, your fuel pump or fuel filter is probably bad.
alot of vehicles will stop running on just a plugged up fuel filter, but normally it will give you some warning, like your engine will start to miss or loss of power on hill or accelerations. If you haven't experienced any problems until now, i doubt its the filter.
see if you can check those two items out and let me know what you find
buy the way, alot of the newer vehicles on the road today use special connection clips to connect fuel lines, you may need a tool to get the line disconnected, there little plastic tools in different sizes depending on the size of your fuel line. if you need one and your doing this yourself, borrow one or at the automotive house ask for a fuel line quick disconnect tool. i don't think there alot of money. make sure your car isn't out of gas.
good luck and let me know how you make out.
would appreciate your feedback, please
Posted on May 23, 2009
jmgldsmth
  • 2005 Answers
SOURCE: 1998 Nissan 200sx dashboard doesn't illuminate
replace the headlight switch
Posted on Jun 01, 2009
sodeep
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
SOURCE: My 1998 Jeep Cherokee cd
it will read burnt cds, the only thing is that it will not play .mp3  format songs, if you can somehow change the format to something else it should work just fine. i had a friend who's car had the same problem and switching the file extension from .mp3 to something else like .mpeg or something else should work. the cd player in a 98 grand cherokee is older and does not have .mp3 play back on it so it cannot read .mp3 format files. that's the only reason it doesnot register. try different audi files out and it should work. give it a try. i hope that helps out some.
Posted on Aug 22, 2009
Where is 02 sensor on 1998 nissan 200sx se
run fault codes to determine which sensor is faulty.
Dec 30, 2013 | 1998 Nissan 200SX
I have a nissan 200sx 1991, it wont start, the radio works,lights but won't start,????
Sounds like your starter motor is bad, but it could also be just a bad starter relay not allowing current to the starter motor. Have the relay checked first, then the starter.
Oct 07, 2010 | 1986 Nissan 200SX
Trying to put a new power steering belt on my 1998 nissan 200sx
http://www.2carpros.com/car_repair_information/year/1997/make/nissan/model/200sx/1997_nissan_200sx_drive_belt_routing_diagram.htm
Jun 26, 2010 | 1998 Nissan 200SX
How do i take of belt on a 1998 nissan 200sx?
There should be a tensioned idler pulley which has an internal spring to take up the slack. It will have a nut or a drive socket so you can attach a spanner and rotate it to relieve the tension. You will need an extension as the tension is quite high. Putting the belt back is easier with an extra person to hold the idler pulley back while you manipulate the belt.
Sep 05, 2009 | 1998 Nissan 200SX
that could be a bad switch. the dim switch may be the problem. its on the lefts side. with the cruise control switch.
Feb 19, 2009 | 1998 Nissan 200SX
Fuel Pump for 1998 200sx
the fuel pump in in the fuel tank.
Feb 13, 2009 | 1998 Nissan 200SX
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
