Question about Mitsubishi WS-55511 55" Rear Projection Television
Ws-55511 power problem
It seems to blink... 1 then 2 then 1 then 2 then 1 then 2.... that is all I belive I can decifer.... i did not notice a pause inbetween blinks..... just 1 then 2 then 1 then 2
  • skipperone1 Aug 03, 2008
    What about my last comment regarding the blinking? Does 20 total blinks mean anything?
  • skipperone1 Aug 04, 2008
    Now it blinks... on, off, on, off... kinda of like 1 blink pause, then 1 blink pause, then 1 blink then pause and it does this for a total of 20 blinks..... what can I do with this code? Thanks, John
  • Mitsubishi Master
  • 8,617 Answers
Ok the 12 code means no error detected. Try this you will see three small wire plugs that run from the convergence yokes on the picture tubes. not the three big plugs, they will be real small plugs all identical. try unplugging them and then try powering up the set. But remember where each one was plugged so you can plug them back in correctly.
Posted on Aug 03, 2008
  • Sonny Berry
    Sonny Berry Aug 03, 2008
    No 12 is the no error detected code.
Will not turn on after manually pressing on button power is connected
TWO QUESTIONS:
1.) DOES POWER LIGHT JUST BLINK?
2.) IF POWER LIGHT COMES ON FOR A SECOND OR TWO AND GOES OUT, do the self check this set has:
when light goes out press and hold both the menu and input (device) buttons at the same time on the front of the set for at least five seconds and release both.
Power light in this case will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will help you.
SD TECH
Nov 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I did the self check on my Mitsubishi 55in Television
IC possibly getting hot and might soon go out. 1 blink then 2 blinks is operating normal
Jan 07, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't power on. WS-55511. Diagnostic is 1 blink then 2 blinks.
The Tv needs to have a system reset that is what the blinking light means. here is how to do.
Use the System Reset button. If this happens frequently, obtain an AC line in power conditioner / surge protector.
Dec 11, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Have a Mitsubishi 55 rear projection WS55511
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blink and then 2 blinks is NO ERROR DETECTED
2 blink and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mistubishi WS-55511 won't stay on
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Sep 17, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Same problem powers on for a couple of seconds
If the code is two blinks short pause two blinks long pause then repeats then over 95% of the time it's because the convergence output IC's need to be replaced as they are drawing too much current. A 2-2 code means overcurrent shutdown.
Jun 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511
thats not a valid error code for mitsubishi.It should blink a series of blinks, for the first digit then pause very briefly then blink another series of blinks for the second digit.
Aug 11, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
Aug 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
