Question about Keurig Coffee Makers & Espresso Machines
Coffee barely comes through, at a very slow speed. I Cleaned everything I could even ,sticking a needle in the pin punch where coffee water meets top of k cup. What else can I do?
    Sergeant:
  • 296 Answers
Wait.
Posted on Mar 21, 2011
Machine states "ventilate." I have cleaned everything numerous times, turned the power on and off, cleaned all water spouts with a needle. How do I get the water to run through the machine?
Go to whole latte love and view their video on ventillating. There is a pump that comes with the machine that will pump water into your machine.
Jan 31, 2016 | Gaggia Titanium Espresso Machine
Keurig says it is brewing. Not brewing.
I just blew a small amount of compressed into the upper needle to clean out the water line to the coffee cartridge . I guess you could use a pin or toothpick to loosen the debris where the needle enters the coffee cartridge as it seems this is where the blockage most likely occurs. I did not disconnect anything but was careful not to use to much air pressure. After cleaning the line I ran a cycle without a cartridge to flush out the line. I have not had a problem for months after doing this. I guess you should on occasion run a clean cycle.
Sep 19, 2014 | Keurig B70 Coffee Maker
Will not brew
Take a tooth brush and clean the little needle like thing that punctures the cup. Sometimes grounds get in there, and block it so the coffee can't dispense.
Mar 09, 2012 | Keurig B31
It is barely brewing. The needle is clean and when I de-scale it, it still only barely comes out. the troubleshooting guide in the book doesn't go any futher.
Put compressed air in the hole under the reservoir that takes the water in, but be sure to unplug it, and clog the white spout that is on the left of the machine also, the compressed air will shoot anything and everything out of the machine. It should get rid of any obstructions.
*****Experience - Did it Myself when Keurig wasn't working*******
Apr 15, 2011 | Keurig B60 Coffee Maker
(B30 mini) no water comes out... we have had it for 3 weeks, I have cleaned the needle... and the funnel. Everything goes as normal, the water heats until it is time for the coffee to come out- then the...
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Jan 11, 2011 | Keurig B60 Coffee Maker
I have a Wesco Moto Cart Jr. 30"X48" Electric Platform Cart 24 Volt. When I turn the rabbit- turtle speed control knob it stays in slow. One of the wires (blue & white) that comes from the motor to the...
re-connect the wire.
Dis-connect the battery and pull the board plug by squeezing the clip and pulling up on the body of the plug.
If you have a bit of tail exposed, then splice the wire back together and tape well.
If the wire has pulled out of the plug with no tail remaining, you will need to remove the pin from the plug with thin needle-nose pliers and attach it to the end of the wire before re-inserting it into the plug.
A soldered pin will be a stronger connection, but a quick-fix trick is to bare a half-inch of copper at the end of the wire, insert it into the pin, and seal it in place with nail polish...The enamel makes a fairly tight and water-proof seal, and a second coat of silicone after re-insertion will protect it further from vibration.
Jun 29, 2010 | GPS
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
Keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Mar 22, 2009 | Keurig Platinum B70 Coffee Maker
Slow coffee stream and smaller brew size with B70
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
Dec 01, 2008 | Keurig B70 Coffee Maker
Slow brewing
I have had that problem with my bunn and I unscrewed the nozzle and it didnt help.My pot came with a wire so long u are totake that wire and stick it up in there and it cleans it out .If that does not work run cleaner threw it but i would not use vinegar.Thats the best i can do,it worked for me.
Jan 11, 2008 | Bunn GR10 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
