My usb Drive Can't showing capacity - Computers & Internet
    Sergeant:
  • 187 Answers
Unplug your USB Drive then plug it again. There should be a notification saying "New Hardware Found" on your taskbar. Check that notification if your drive is working properly.
If not, go to Start>Right Click on My Computer>
Click Manage>...Then Choose DIsk Management>
Look for your removable storage device>
Check the capacity and the drive letter if there was no conflict with other drives of your partition>
If There's a conflict, Right Click and choose "Change drive letter and paths..."> Then change the drive letter of your USB drive.
Posted on Mar 21, 2011
My HDDR500E03A 500 GB is only showing 3.98 GB on total memory, what happened to the rest?
The 3.98 GB you are seeing is probably your total RAM memory and not the storage capacity of the hard drive. RAM memory is completely unrelated to the hard drive capacities.
Double click on the MY COMPUTER icon.
You should then see all the disks and drives that are currently connected to your computer. Your USB hard drive should be one of the drives listed there.
Right click on each of them and select PROPERTIES from the menu shown. This will show you the storage capacity of each drive including how much space is used and how much is free (empty).
Good luck.
Mar 15, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
My TRANS-IT USB Flash Drive is showing a problem 'cannot identify the capacity of the flash drive' and shows no spaces available
THIS HAPPEND TO ME TOO WHAEN I INSTALLED A NEW VERSION,
ITS OK IF U R WORKING WITH NEW VERSION.
NEW VERSION ONLY GIVES U ACCESS UPTO THE INSTALLED OLDER VERSION INSIDE.
GUST PLAY WITH LOG IN AND LOG OUT OPTION, IT WILL HELP U TO SOLVE UR PROBLEM.
BETTER TO REMOVE SOFTWARE AFTER ACHIVING UR FULL CAPACITY.
May 20, 2010 | TDK (CD-RW74HSFXS5) Storage Media
My capacity genx 2gb usb chenge to 14 mb.when i connect flash disk i show cd drive added in my computer and capacity my flash disk cheng of 2 gb to 14 mb.plz help.my email shaab.a@nisoc.ir
This typically means the drive has gone bad. Try reformatting the USB drive. Some manufacturers also provide diagnostic/formatting tools on their website that might be able to fix it. But likely it will need replaced. Lucky 2GB USB drives now only run $7.99 or less.
Apr 20, 2010 | Computers & Internet
How to remove write protection from 8gb pen drive. I have installed many softwares but it shows ''Disk is Write protected''. Please help to solve this problem.
hi,,
ok on the pen drive itself,, is a small switch with a lock on it at one end,, and an open lock on the other.. Its a small switch,, usually at the sides or back of it.. just push the switch in the other side to unlock it..
if there isnt one..
Regarding the write protect error, I believe its a common symptom for fake USBs. These are ones which say they have large capacity, but the seller placed a much smaller capacity chip. In your case, its possible that the pen drive's REAL capacity is only 256MB! Even the OS is fooled into thinking its a large capacity USB drive.
I saw some Sony branded USB's with a capacity of 32GB a few months ago. They are obviously fake.. but I do wonder how many people fell for them.
you can try formatting the drive ,, by
  • start
  • computer
  • right click on removable disc (your drive)
  • click format
well I hope that helps you out.. Other than the above there isnt much more that can be done..
Mar 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
WD MyBook Premium not showing any capacity using Firewire
There seems to be a firewire port issue on the device. Why not leave it USB?
Jun 05, 2009 | Western Digital My Book Essential Edition...
Dont Show the Pen Drive in my System
Make sure your system can support that capacity.
Jan 06, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Problem in pen drive/mp3 player capacity
when you hook it up to the puter, go into My computer right click on the removable drive then click on explore disc and see what oter types of files are taking up the extra memory as if there are none then the drive has bad memory cells.
Apr 28, 2006 | Sony NW-E405 MP3 Player
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
