Question about Lexmark E250dn Laser Printer
I have a Lexmark E260 printer and get ink marks along the edges my printed sheets about 1/4 inch wide on both sides. How can I fix this??
    Genius:
  • 1,087 Answers
Please click on the link to see instructions on how to go about the procedure. http://bit.ly/pq6FU3
For further assistance, please contact Lexmark Technical Support.
Posted on Jul 14, 2011
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
Mar 04, 2011 | Lexmark E260dn Laser Printer
Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Dec 30, 2009 | HP LaserJet 1100 Printer
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Lexmark E250dn Laser Printer Logo
304 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
