Question about Optoma RD65 65" Rear Projection HDTV
Optoma rd65tv will not turn on - Optoma RD65 65" Rear Projection HDTV
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck....
Posted on Mar 21, 2011
Optoma sky code
058,051. Try these codes. If you wish to get more, check the sites linked here. It has setup codes, and setup procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 23, 2013 | Optoma Televison & Video
Optoma hd65 doesn't turn on
same for me and a few other people on this site **** from Optoma!!
Jul 08, 2010 | Optoma HD65 DLP Projector
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Projector will not turn on no fan no light
Hi!
Here is a link to the "Troubleshooting" part of the manual to Optoma H56 Projector. Hope it will help!
Troubleshooting Optoma 56 User Manual Page 27 of 32
Jan 04, 2018 | Optoma H56 Multimedia Projector
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
Optoma RD65 65" Rear Projection HDTV Logo
204 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
