Question about HP Compaq tc4400 Notebook
Hi i made a partition on my hard drive and when i turned my laptop back on i get this message, non system disk or disk error replace and strike any key when ready can you help please thanks ross
  • 33 Answers
If you create a new partition on your hard drive with anything but partition magic or something similar, the process of creating the partition will wipe all data from the entire hard drive to resize the partition. you will probably need to re-install Windows fresh unless the utility you used just happens to have an undo (not very likely) playing with partition sizes of used drives is not advisable.
Posted on Mar 21, 2011
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My hp laptop shows non system disk or disk error
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
MY LAP TOP MESSAGE SAYS... 1782 DISK CONTROLLER
You are getting this mess because the system is not able to detect a boot partition on the hdd or may be it is not able to detect the HDD itself.
Try to remove the HDD(hard disk) and re-seat it, Also make sure that there is no disk in the CD drive (in case the first boot device in the BIOS is set as CD drive).
Go to BIOS by pressing F10 (system setup) and check if the HDD is detected in BIOS.
Try to run a recovery by pressing F11 on first screen after power on.
Please get back for any further assistance.
Thank you for choosing Fixya
Feb 24, 2010 | Compaq Armada E500 Notebook
Non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
Error message Non system disk error replace and strike any key wh
Hi !
This error means either there is no disk (or disconnected/wrong connected) or your HDD is gone (which I don't believe) !
I can't find a reason why you pulled out your HDD when it was (I assume) working good before ?!?
Anyway, . . .now, please check carefully the connectors - both sides, to the HDD and to the Board(if any), if they are properly fit!
It is an IDE disk and there are two groups pins on the HDD. Check the pins if they are all going to plastic male connector (and then to the board.
A group of 4 or 6 pins on HDD should not be connected. There is one pin missing in (about) middle of the second row of pins - it is o.k.
Put your ear close on the chasis of laptop and find if there is a spinning noise when you turn your laptop on.
If there you can hear noise, then check in BIOS if your HDD exists.
If not, try to check it on another Laptop/PC.
Regards.
Apr 22, 2009 | Compaq Evo N800C Notebook
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    get a new hard drive and reinstall software + OS
    May 06, 2008 | Compaq Armada E500 Notebook
    "Non-system disk or disk error replace and strike any key when ready".
    If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
    Apr 10, 2008 | Compaq Evo N610C Notebook
    HP Compaq tc4400 Notebook Logo
    80 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
