Question about Lightning Audio Bolt B2.350.1 Car Audio Amplifier
My Amplifier is in protect mode... i pulled it out of one vehicle where it was working fine and attempted to put it in another vehicle and it automatically went into protect mode i then tried to see if it would work in the original vehicle but it still says protect. i checked all my wires and everything so that is not the problem. i was wondering if there is some kind of like reset button or something along those lines.
    Sergeant:
  • 296 Answers
It's blown. Check the fuses, if the fuses are fine the the capacitors on the amp are blown.
Posted on Mar 21, 2011
Goes straight to protect mode, detached speakers, still same problem
HI, if the unit is in protect mode then there may be the possibility that the speaker wires may have a short circuit in them or that the amplifier section may be damaged....you can remove the radio from it's sleeve and check the wiring behind the unit...this also would have to be done to see the model number and serial number...it should be on either the top or bottom of the unit...the speaker wires for this unit are the white, gray, green, and violet...each with another of the same color but has a black stripe in it...the black stripe is the negative side of the speaker wire....you can disconnect these wires, then turn on the unit to see if it comes out of protect mode...if it does, then there is either a bad wire somewhere in the car or a bad speaker...if the unit stays in the protect mode, then you will have to take the unit in for repair, as this indicates a circuit failure
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, usually with the green power LED on the amp turning to red or orange. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amplifiers can go into protection mode for several reasons. Knowing what happened before it quit working can help determine how to fix it. Did the amp malfunction as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amplifier touching metal.
Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle. Don't let the amp touch the screws used to moun the wood board and don't use screws so long to mount the amp that they go through the board and touch the vehicle.
3. If the amp is OK in this torn down state start reconnecting wires until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor as well as return shipping. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
Hope it helps..
Aug 10, 2011 | Sony STR-DE698 Receiver
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
I have an mtx amplifier. it worked for a while then it just cut out, still turns on, no blown fuses, no smoke or funny smell, speakers work. what could be wrong with it
Looking at alot of the unsolved FixYa problems - I can see alot of "My amplifier is going into protect mode - How do I fix it?"
There is no catch all or simple answer. Troubleshooting2.gif steps must be taken to determine what is causing the problem.
It is one of 3 things....
1. Impedence under rated value or Thermal Protection.
2. Short to ground in wiring.
3. Internal Component Failure.
One of the more confusing things with a car stereo can be when the amplifier goes into protection mode. One minute it's working and the next minute it's not. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amps2.gif can go into protection mode for several reasons. Knowing what happened before it cut out can help determine how to fix it.
Did the amp not work as soon as it was turned on?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amp touching metal.
Remember that an amplifier2.gif should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier.
3. If the amp is OK in this torn down state keep adding the other wires back on until you find what causes the problem.
If the speaker wires cause the problem then they are probably touching metal or have a blown voicecoil.
If the problem starts occuring when you connect the subwoofer wires to the amplifier you may have your subwoofers wired at too low an impedence. First check the spec's on your amplifier to make sure what kind of loads it is stable under. Then check the wiring configuration to make sure that your load is not too low:
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor.
Thanks for using FixYa - a 4 THUNMS rating is appreciated for answering your FREE question.
Oct 13, 2009 | MTX Thunder 801D Car Audio Amplifier
Light
The red light indicates that your amplifier is in protect mode. Amps go into this mode if there is something wrong with the setup of the system to prevent fatal damage to the amplifier circuitry. This is bad thing since the amplifier will not function until the problem is solve and it can remove itself from protection mode.
Amplifiers can go into protect mode for many reasons but one of the most common is incorrect mounting. Is your amp sitting on the metal of your vehicle? Is it bolted down and screwed into the metal of the vehicle or your seat? The amp should never be touching any sort of metal. Only the ground should touching the metal of your vehicle.
Speaking of grounds, many people often neglect proper grounding which can cause an amp to go into protect mode. Do you have a solid ground? Is the wire less than 3 feet long and directly connected to a non-painted metal part of your vehicle? Is the ground wire the same gauge as your power wire?
These are just a few reasons why an amp can go into protect mode. You can find more information here. Or simply google for why your amp is in protect mode.
Aug 06, 2009 | MTX Thunder 81000D Car Audio Amplifier
Xplod XM-DS1600P5 red light
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Nov 30, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
500.1 amp power lights blinks on and off
Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Below information is from the manual:
Status Indicator Lights / Protection Circuitry
There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
For information on troubleshooting this amplifier, refer to Appendix E (page 21).
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Low ohm light wont go off
It's likely that the output transistors failed in the amplifier and it will need to be repaired.
Nov 08, 2007 | Jl Audio 500/1 Car Audio Amplifier
Lightning Audio Bolt B2.350.1 Car Audio Amplifier Logo
184 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Richard Lukszys
Richard Lukszys
jason
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
