Question about Samsung B5722 Cell Phone
I want to rest default java test menu and help me
I want to rest default java test menu and help me fix erorr java i change all menu in java test menu but my mobile not do java games help me
    Sergeant:
  • 296 Answers
Need a new phone.
Posted on Mar 21, 2011
    New Friend:
This is not working for dual sims... plzz help
Posted on May 16, 2013
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    How to fix ctk 7200 keyboard sdcard erorr
    SD or SDHC memory cards must be between 2GB to 32GB
    1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
    Feb 07, 2014 | Casio CTK-720 Electronic Keyboard with...
    Send me sumsung champ all secret codes ....??? m nt getting exact codes pls help me soon
    General Diagnostics: * *#0*# - LCD Test Menu. * *#06# - Show the IMEI number. * *#367# - DB Profile Setting Menu. * *#1234# - Displays the Firmware Version * *#9324# - Phone Monitor. Press up and down to display more. * *#0228# or *#9998*228# - (BAT) Battery statistics. Press up and down to display more. * *#0289# or *#9998*289# - (BUZ) Buzzer test. * *#0638# or *#9998*638# - (NET) SIM network ID. * *#0746# or *#9998*746# - (SIM) SIM Information. * *#0778# or *#9998*778# - (SST) SIM Service Table. Press up and down to display more. * *#0782# or *#9998*782# - (RTC) Real Time Clock Display. Press the "#" key to refresh * *#0842# or *#9998*842# - (VIB) ******** test. * *#1111# or *#9998*1111# - Displays the Software Version. * *#1234# - Displays the Firmware Version. * *#2222# or *#9998*2222# - Displays the Hardware Version. * *#4357# or *#9998*4357# - (HELP) Code help screen. Press up and down to display more. * *#4777*8665# - GPRS Test and Configuration Menu. * *#5002*8376263# - Additional handset information. Press up and down to display more. * *#9998*76# - (PN) Production Number. * *#9998*377# - (ERR) NVM error log. Press up and down to display more. * *#9998*667# - (MMS) MMS Debug. * *#9998*968# - Yamaha test. * *#9998*982# - Edit IM settings * *#9998*2576# - (BRKN) SIM Error. * *#9998*3323# - (DEAD) Forced Crash. * *#9998*5282# - (JAVA) Java Profile Menu. The "Install MIDlet" password is "235282′ * *#9998*5646# - (LOGO) GSM Logo set. Press up and down to set.
    WAP Configuration: * *#82# - Display WAP User Agent. * *#92782# - Edit the WAP User Agent. Default setting is "SEC-SGHD807/1.0 TSS/2.5′ * *#827# - Display WAP UA Profile. * *#927827# - Edit WAP UA Profile. Default is setting "http://wap.samsungmobile.com/uaprof/d807_10.xml"\
    Digital Audio Interference: * *#3243948# - Digital Audio Interference (DAI) OFF (Resets Phone) * *#32436837# - Digital Audio Interference (DAI) ON
    Bluetooth Configuration: * #*3888# - Bluetooth test mode * *#232337# - Displays Current Bluetooth MAC address * *#7263232337# - Changes Bluetooth MAC address. A random number is chosen and you will lose all your previous bluetooth connections. Use with caution!
    Reset Codes: Data in the phone will be deleted! * *2767*3855# - Full reset * *2767*2878# - CUST reset * *2767*927# - WAP reset * *2767*667# - MMS reset * *2767*36245# - Email reset
    Feb 28, 2011 | Cell Phones
    I have samsung C3510 Genoa. this cell phone is not supporting jar file exceeding size of 500 kb. please give solution...
    Enter this code in standby mode: *#52828378#
    You will see "JAVA Test Menu" screen. Select option # 6 which is "OTA Test". Here you can see "Maximum JAR size (KB) which is 400 KB by default. Just enter your own value like 2048 KB. Press "Save" and exit from it. Now you can install JAR file of upto 2 MB size. Keep in mind that your new setting (2MB) will change back to default value (400 KB) if you RESTART your mobile. So, this is just a temporary setting but works perfectly to install large JAR files.
    Oct 06, 2010 | Samsung C3510 Cell Phone
    I have samsung champ gt-c3303 .It cannot run any java supported file what can i do for it ?
    Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
    Oct 05, 2010 | Cell Phones
    When I try to open my MP3Rocket I get the following error: ''Unable to access jarfile libMP3Rocket.jar''. Can you please advise me? Thanks
    1. Open Default Programs by clicking the Start button, and then clicking Default Programs.
    2. On choose the programs that windows uses by default, Select “Associate a file type or protocol with a program > Click on the extension (.jar) to view the program that opens it by default.
    3. Click change the program and select the default program JAVA virtual machine launcher
    4. Click close.
    Change-which-programs-Windows-uses-by-default
    http://windows.microsoft.com/en-US/windows-vista/Change-which-programs-Windows-uses-by-default
    Now check if the issue is resolved
    If the issue persists, you may want to uninstall and reinstall JAVA.
    How do I uninstall Java on my Windows computer? http://www.java.com/en/download/help/uninstall_java.xml
    How do I manually download and install Java for my Windows computer? http://java.com/en/download/help/windows_manual_download.xml
    If the issue still persists, you may want to check with MP3 rocket for any known issues
    http://www.mp3rocket.com/support/
    May 03, 2010 | Microsoft Windows XP Professional for PC
    Java
    Open the Java applet in Control Panel and check Internet Explorer is selected under Default Java for Browsers under the Advanced tab.
    Dec 15, 2008 | Computers & Internet
    Cant get a game to load
    YOU HAVE A Choice of using 4 kinds of Javas 1. the default Java,2. SunJava, 3. unsigned version of the default Java. 4. Microsoft Java. I have also found this problem., it happens after you rebooted your computer after installing 6u1 version of java.
    To fix this go to your controll panel>Add or Remove programs then look for java, you should have two different versions there, 5u11 and 6u1 uninstall 6u1 and reboot you computer.
    Hope this helps.
    Sep 30, 2008 | Sun Computers & Internet
    Samsung B5722 Cell Phone Logo
    169 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
