I have a canon imageclass MF4380 and i had a paper jam and could not get all of the paper out...i can't see it anywhere yet it makes a noise when i print again so i know its still in there. How do i get the machine open enough to find it.
SOURCE: canon imageclass printer 5550
Did you ever find a resolution to your canon MF5550 paper jams? I'm having the same issue and it's incredibly frustrating! I haven't found any help through Canon's website either.
Posted on Feb 29, 2008
Tech4all
  • 6 Answers
SOURCE: paper feed problem with Canon ImageClass D860
Hi Dfra. Here is the link that show "how to clear jams"
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=10517#SupportDetailAct
Good luck.
Posted on Feb 25, 2009
1alexh
  • 484 Answers
SOURCE: Paper Jam error will not reset after removing jammed paper
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
Posted on Jul 02, 2009
kytarheel
  • 8 Answers
SOURCE: my canon ip1800 paper jam
Turn it upside down and shake vigorously. Also, is there a reset hole where a paper clip inserted can do a system reset?
Posted on Aug 22, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
Paper Jam on the Canon Imageclass MF6530
Make sure that there aren't any tiny pieces of paper stuck in any of the rollers or gears. This can cause that as well.
Dec 10, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
It says Paper Jam, but there is no paper jam anywhere what can i do
Torn pieces of paper while removing can jam your printer. Check the optical sensors in paper path. You will find these sensors in the middle or at one end of the paper path.
sonsunny
Jun 18, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
I have a Canon ImageClass D320 copier. It keeps
open the right door and see if any of the sensors are stuck... or out of place... if not then get a can of air and blow out the dust in each sensor...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 15, 2009 | Office Equipment & Supplies
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Dec 06, 2007 | Canon imageCLASS D780 All-In-One Laser...
Canon imageclass printer 5550
I have crazy feeding/paper jam problems with my MF5650.
Oct 06, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
203 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
