Question about Kenmore Washing Machines
Water will not drain out of machine - Kenmore Washing Machines
  • Kenmore Master
  • 2,699 Answers
Is it dead with water still in it?if so check the lid switch,lift up the lid,put it on spin,stick a screw driver into the hole where the lid switch strike goes into,see if it spins and drains,if it doesn't do anything push the screw driver in and out,if there's a clicking sound the lid switch is good and now you have to check the pump.if you have a shop vac vac out all the water out of the tub and then go to this site and it will tell you how to get at the pump,when you get the pump off look inside to see if anything is jambed in it.................. Washing Machine Drain Pump Replacement (part #3363394)
Posted on Mar 21, 2011
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Water not draining
It must have drained water out at some stage because it got to the end of the cycle.It sounds as though the pump may be blocked.The pump can be gotten to by removeing the rear panel on the back of the machine,make sure the machine is unplugged.water will come out so first try syphoning the water out of the machine.if the drain hose comes out from the bottom of the machine then just lay it down into a bucket to get the water out.
Jun 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water coming out of hose at home plumbing
Hello.Maybe the drain is blocked.it sounds like your machine is working ok to me,if you can hang the hose over the edge of a laundry tub & make sure the plug is out,see if the water drains away,otherwise it sounds like a plumbing problem not the machine.it started only after you moved houses so more likely the plumbing.hope i helped.
May 28, 2010 | Maytag HAV2557 Top Load Washer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
