Question about Whirlpool Duet GHW9150P Front Load Washer
Water doesn't drain out. keeps getting 2 different errors F01 and F27. what does mean?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
F1 is a pump drive failure and F27 is an overflow condition. Both point to a pump problem. Remove the front panel and unscrew the pump filter. Water will come out, so be prepared! If the pump filter is clean, you will likely need to replace the pump.
Kelly
Posted on Mar 21, 2011
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
What is F27 error code?
The F27 error code indicates an overflow condition. If the washer is overfilled and continues to fill with water, this would indicate that you have an inlet water fill valve that is stuck open. If you unplug the washer and water continues to fill the tub, then the inlet fill valve assembly will need to be replaced. Make sure that the drain system is properly installed according to the installation instructions. An improperly installed drain system could result if siphoning of drain water back into the washer.
Check to see if the drain pump is working properly to pump out the water. When the F27 occurs, the drain pump will run constantly to pump out the water. The door will remain locked. Shut off the water supply faucets behind the washer. If water is not being pumped out of the washer, you could have a clog in the drain pump or drain hose. The following link of a previous answer provides advanced troubleshooting for a drain problem:
Why won't my HE4t washer drain?
If the washer is not overfilling and the F27 remains even after the washer is drained, then it is likely that you have a failed pressure switch. A failed electronic control board in the washer could also cause this problem. To access the pressure switch, unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and pull the top panel slightly back and then up and off of the washer. Sometimes, you can reset a stuck contact in a pressure switch by tapping on it with the handle of a screwdriver. I you cannot reset it, the pressure switch will need to be replaced. If you have the same problem after replacing the pressure switch, you will likely need to replace the control board in the washer.
Aug 19, 2014 | Kenmore Washing Machines
Hi I keep getting an error message "F27" on my
F27 OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Aug 31, 2011 | Bosch Axxis WFL 2060 Front Load Washer
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancelbutton to remove error displayed and restart the cycle. If it doesn't work, it means thatthe valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens Washing Machines
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
servicing.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
Check
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The F21 signal keeps flashing.
f21 is long drain, failed to drain in 8 mins. f27 is overfill, overfill contacts on pressure sw closed. If unit did actually successfully drain normally then pressure sw is likely the problem.
1. did pump come on? if no replace pump
2. is unit draining at normal rate? no then clean pump.
if yes on both replace pressure sw.
to second poster if getting suds error when using HE then you likely are using to much detergent. If avail run a clean washer cycle.
or normal cycle with bleach or fabric softner, no clothes
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
590 people viewed this question
Dan Webster
Dan Webster
Sal De
