Question about Sirius Satellite Radio Audio Players & Recorders
My unit is turning off when I hit a bump. I have two different bases in 2 different vehicles and it's doing it in both. So, it's something in the unit itself rather than a connection. Any ideas?
    Scholar:
  • 149 Answers
You power jack has come unsoldered. You can try to resolder it yourself, or buy a repair service from someone on ebay.
Posted on Mar 26, 2011
Have a 2007 Dodge Dakota keeps stalling when hit bumps and turn
Only 2 thoughts come to mind having had vehicle with similar issue. 1) Iffy electrical connection to fuel pump that jostles loose on bumps and turns. Or 2) worse, a pinhole leak in the fuel line that unless jostled away from frame or other point of friction that made the pinhole runs fine but when contact lost from "plug" it sucks air and air hits carb/injectors. A Chiltons/Haynes repair manual may well give some answers other than what I have to offer.
May 02, 2017 | Dodge Cars & Trucks
Bumping noise in rear of Buick LeSabre
If you have fitted new shockys I suggest you check the travel of the units as it sounds as if they are bottoming out Pistons hitting bottom of internal cylinder.
May 26, 2013 | Cars & Trucks
I put a torsion key lift on my 98 silverado(new offset torsion keys cranked all the way up for around 2 inches of lift) wondering if there's anything I can do besides lowering it to ease out the ride. I've...
if you alter the standard ride height where standard travel shocks are installed , you have to alter the shocks to accommodate the difference in travel for the shocks
2" higher = 2 "longer shocks or 2"' lower =2 " shorter shocks next use a shorter bump stop for the arms so that the stop is not hit on the slightest bump
remember that the engineers design the car for maximum stability and ride comfort and when you decide that you are not happy and change it then stability , road handling and comfort all go out the window
Oct 19, 2017 | Cars & Trucks
Put a torsion key lift on my 98 silverado. Thts new offset torsion keys cranked up for around 2 inches of lift. Truck rides rough as to be expected but it's so bad when yu hit a bump it just bounc
BY raising the body 2'' you have in fact extended the travel required in the shockys by 2''. IN short the piston in the shockys are probably now hitting the upper end of the case inside. The bump stops for the upper arm will now have extra clearence if they are on top or probably no clearence if they are situated under the arms. In raising the body I hope you took into account the new drive line angles for the drive shafts as they will now be operating at a different angle close to max permitted,and will result in premature shaft failure.
Mar 03, 2013 | 1998 Chevrolet Chevrolet silverado
My Alante cuts off/stops when I hit a bump. I have to turn it off and restart all over again until i hit the next bump. this is very annoying and dangerous if i hit a bump crossing the street as I am stuck...
More than likely there is a loose connection somewhere. It could be at the batteries, the joystick or both. First I would need to know if it is an Alante or an Alante Jr.
Can you provide me with the serial number off the unit?
May 09, 2011 | Golden Technologies Alante 2 Heavy Duty...
I hit a bump at 65 on freeway and my jeep 2006 jeep wrangler unlimited with 28000 miles went into a death wobble what do you think caused it and what needs to done to correct it?
You will want to look for a broken sway link on the front or back. On the front it's normally a vertical piece made of metal or plastic that connects the fat rod going across the front of the vehicle to a knuckle near the base of each shock tower. On the back it is similar vertical piece,but it may look a little different than the front.
Aug 03, 2010 | 2006 Jeep Wrangler
Suspension and steerin wheel
It is difficult to just assess wut is causing the suspension knock. U will have to go under the vehicle or let someone who is experience about this do it. Go under the vehicle and check the entire suspension system, steering ends, rack ends, ball joionts, rubber bushings etc. Well u said u have changed ur shocks but no difference. As for the squeaks, this might be coiming from the universal joint from the steering column. Like I said they really have to be inspected.
Jan 27, 2009 | 2000 Jeep Grand Cherokee
Registering handset to base
I reviewed the user guide for that model, and I only see that it is an answering machine. I may indeed be wrong, but is there a chance you have a different model unit? Regardless of the model, normally you have to put the base in registration mode simultaneously when the handset it put in registration mode like you were doing before. If you do not have the user guide you can join Beoworld.org for $27 a year and download it for "free". I am curious to know if you have a different model or if you can register cordless handsets to the 1200. Maybe you can post an update. Just learning this model myself. Good Luck
Feb 01, 2008 | Bang and Olufsen Beotalk 1200 Digital...
95 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tom Chichester
Justaguy
Level 1 Expert
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
