Phillips 55 in. rear projection tv
Where can i get the coollant and can i put it in myself. the tv repair shop out here want 75-100 dollars just to look at it
  • 8,617 Answers
You can get the entire to replace the coolant for less than what the tV shop wants to come look at it. And the kit comes with all the coolant for all three tubes and has the instruction CD which explains the entire coolant change process step by step with pictures. Its a very easy process with the CD. Plus they have free instant message tech support in case you need help. Its listed under the repair kit category, and its called phillips CRT coolant replacment kit.
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 03, 2008
My phillips big screen has double images in picture and words. how do i correct it?
Convergence is dead.Know how to solders?Must replaced 2 convergence ICS,and all it resistors.Buy a convergence kit at Tv repair World.com.Tvrepairkits.com to repair it ur self.The shop will cost $300 for parts and labors.
Feb 06, 2010 | Philips 55PW9363 55" Rear Projection...
My Phillips 55PW9363 tv has a double image problem, how can i fix it?
Ur convergence is dead.Know to solders? Require changing 2 convergence ICS,and all the resistors.Tries Website Tv repair World.com,Tvrepairkits.com.for the convergence kit.Shop will cost U $300 for parts,and labors.
Jan 25, 2010 | Philips 55PW9363 55" Rear Projection...
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
I have a 60 inch phillips rear-projection tv and there is no picture . There is a whinning sound and the light flashes at the power button. Can I fix it myself or does it need to go to a shop
it is better you get a repair guy to first open the set and to determine the exact problem.
the thing is you may make it worse if something goes wrong
Aug 26, 2009 | Philips 55PW9363 55" Rear Projection...
Aspect ratio and tv type
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Jun 20, 2009 | Philips 9P5544C 55" Rear Projection...
What can i do to get a new screen without spending alot of money
you may be able to find one used at a local repair shop as most shops save them when they part out rear projections that arent worth repairing. Other than that replacement screens are several hundred dollars if you can find them.
Jun 14, 2009 | Toshiba 55H70 55" Rear Projection...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Phillips 52" big screen is looking blurry. Can I tune it myself?
my projection tv color is red I have tried ajusting the color but nothing the pic is still to red
Jul 07, 2008 | Philips 55P8341 55" Rear Projection...
Comes on then shuts off
Hello Mha8649,
The TV shuts off because the shutdown circuit it turning the TV set off. The shutdown circuit does this because of an over-current condition. I would advise that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank you,
Shuttlr83
Oct 15, 2007 | Philips 55PW9383 55" Rear Projection...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
