Question about Hoover U5227-930 Elite Upright Vacuum
How to install new belt? doughewines@yahoo.ca
  • 240 Answers
First lay the vacuum on it's front side and remove the bottom plate covering the agitator. It is usually held in place with 2 tabs,although there may also be screws. The upper cover can be removed next. Pry it loose by inserting a screwdriver along the outer sides. There are usually small arrows molded into the base indicating the places where tabs hold the cover on. You may want to pull off the heigth knob on top of the cover first. Place the new belt ( #38528040), around the agitator, and push the belt through the opening in the base. Next the belt must be stretched around the motor shaft. This will require some strength, as the belt must be stretched a fair distance. It is best to use a strong screwdriver as a lever.
Posted on Mar 21, 2011
I can't find a user manual for my Eureka Model UMC-18 central vacuum system!
I have a manual that I can send you, drop me a line at my email and I will attach it back to you.
thanks
Mark
bartmkh@yahoo.ca
Nov 11, 2010 | Eureka 1810 Central System Vacuum
WHERE DO I FIND A REPLACEMENT BELT FOR MC V7305
Any Vacuum shop should have this, and depending where you live, canadian tire, walmart, target, Sears should have the belt.
If your not close to any of those places, let me know and I will try to help out better.
Good luck,
Mark
bartmkh@yahoo.ca
Nov 07, 2010 | Panasonic MC-V7305 Upright Vacuum
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Oreck vaccum
The belt must not be running true to the pulley. You may need a brush roll, but also check the motor to make sure it isn't moving inward after the belt is put on.
May 17, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Changing a vaccum belt
Most of the Dirt Devils, turn the vac. over, remove the bottom plate, then you can get to the belt and brush roll. If the bottom plate doesn't come off, then from the top, there will be 2 or 3 screws to remove, then the top cover comes off to reveal the belt and brush roll.
Nov 03, 2007 | Vacuums
Hoover U5227-930 Elite Upright Vacuum Logo
61 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
