Question about Whirlpool Microwave Ovens
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
  • 6,993 Answers
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck....
Posted on Mar 21, 2011
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave turntable won't turn
You will have to take it out and then take off the outer cover to expose the drive system for the turntable unless the items turns with the turntable removed. If it does then (and if it is belt driven) the belt may be worn and slipping. Anyway you look at it the cover has to come off to see what is happening.
Feb 08, 2008 | Jenn-Air JMC7000 Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Microwave Ovens Logo
215 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
