Question about GoVideo Go Video DVD/VCR Combo
Buzz during playback, but only on SOME tapes!! When i adjust tracking manually, pictures quality suffers.
  • Madeleine Tiktin Mar 23, 2011
    So i do not underestand: are you recommending i have the heads demagnitized or not?
  • GoVideo Master
  • 8,457 Answers
Bad recording VHS or old VHS tapes,will sometimes causes this problems,because of degrading magnatic tapes.Sorry this problems,u did the fixed adjusting manual tracking,that it not fixing the problems,sorry that all u will getting that kind of quality of picture.
Posted on Mar 21, 2011
Testimonial: "Excellent, intelligent answer!! I will use new tapes from now on. Thank you!"
    Master:
  • 414 Answers
I would have the head demagnetized and cleaned on the
unit. Many times it will make the problem worse if you have worn tapes. You can clean the head with a head
cleaning tape, but you may need to take it to a shop
to have the head demagnetized (considering the cost
of purchasing one).
Posted on Mar 22, 2011
    So i do n ot understand: are you recommending i have the heads demagnitized or not????
  • fixingthings Mar 23, 2011
    Yes, have the heads demagnetized.
SOURCE:
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
Oct 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I HAVE A TOSHIBA VCR/DVD COMBINATION MACINE. THERE IS NO TRACKING BUTTON. iS THERE A WAY TO AUTOMATICALLY ADJUST THE TRACKING??
Usually VCRs do not offer specifically labelled tracking buttons as such, however they may incorporate tracking into their channel UP/DOWN buttons, both on the front of the main unit and/or remote. Some brands also offer V-LOCK (vertical lock or still image adjustment) (in pause mode during playback) to stabilise the image, reducing vertical jitter, which again can be adjusted as required using the same buttons as used for tracking. In most cases, pressing both CH UP and CH DOWN together while the tape is playing should centre track (revert back to auto tracking) the unit.
I am sure if your VCR has channel buttons on it, try pressing either one while a tape is playing. See if it affects the tracking at all. If it does, press both buttons together for 5 seconds or so, then release - auto/centre tracking takes over.
It costs nothing to try this, and it won't hurt your machine or your tapes.
Apr 20, 2011 | Toshiba W522 VHS VCR
My vcr has a shaking sensation during playback. I
Likely capstan motor and/or pinch roller worn. Probably more than new VCR.
May 02, 2010 | Sony SLV-N750 VHS/S-VHS playback VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Flicker on playback
Could be tracking, dirty / faulty heads, or mis-alligned guide rollers.
First,adjust the tracking on the player during playback. This is done by pressing P+ or P- on the remote control.
If this doesn't work, use a video head cleaner. This consists of a video cassette and fluid. Follow the instructions with the cleaner.
If this still doesn't help, and you are confident in opening up the VR550, you could cleaner the heads manually.
Disconnect from the mains.
Remove the screws from the back and sides of the VCR.
Gently ease the lid off the machine.
Locate the large silver coloured head drum towards the back of the machine. There are four small receptors around the side of the drum. These are the video heads.
Take a small piece of clean white paper about 1.5 inches square. (Copier paper)
Hold the paper square over 1 finger and rub each head in turn. Keep the head near the centre of the paper so as not to catch the heads with the edges of the paper.
Check the paper for dirt from the heads.
Reconnect the player and try a tape. If the problem is still there, try cleaning again.
If none of this works, insert a tape NOT recorded on this machine (Mis-alligned rollers affect recording as well as playback) and play. Locate the rollers which guide the tape around the mechanism. Particulary either side of the head drum.
The rollers have adjustments on the top, which can be turned to move the guide up and down slightly. This is a fiddly job, and over adjustment could cause the tape edge to be damaged.
Adjust the rollers to get a clear picture. It is mainly trial and error.
If all fails then the video is probably destined for the skip.
If you need a replacement, www.cheapestelectrical.co.uk , will sell you a VR550 at a very good price.
Apr 09, 2008 | Philips VR550 VHS VCR
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
My camcorder not playing back
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
Mar 17, 2007 | Panasonic Palmcorder PV-GS14 Mini DV...
GoVideo Go Video DVD/VCR Combo Logo
185 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
