Changing the coolant fluid on a magnavox 6p6030
We acquired a Magnavox 6p6030 projection tv and need to change out the coolant. Can you direct us on how to do this or tell us where we can download a free service manual.
  • 8,617 Answers
There is no free service manual for your model as its a large service manual that covers many models. You can however get the Phillips coolant replacment instructional CD, or the entire coolant kit with the coolant and instructional CD at the following link. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Aug 03, 2008
Bad dull color on a magnavox 55p8288a... how do I change the coolant in this tv
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
  • Screen looks 3D
69189a5.pngSOLUTION
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to change crtfluid
Only a qualified service tech should replace coolant fluid. I've serviced TV's for a good while, and I would not attempt this repair without a co-worker showing me precisely what to do. You have to remove the Picture Tube(s) to do this, and if they leak after assembly, your TV circuit boards could be totalled out. The coolant is similar to anti-freeze and is corrosive.
Apr 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Changing fluid in CRT's
You can go to the following site, under the repair kit catagory they have a CD that documents the step by step proceedure for coolant change in phillips / magnavox tvs with pictures. They also have the entire kit with 48 ounces of high purity coolant and the cd
Heres the link.
Jul 11, 2008 | Televison & Video
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox model# 6p6030-w101
change the coolant in the green and blue CRTs. Then also poloish the mirror by cahnging the coolant your set will be as bright as when it was new. If you need more info, please let me know.
Apr 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
CHANGED COOLANT OIL
Where did you buy the coolant oil?
Jan 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
