Question about Samsung 215TW SyncMaster 21" LCD Monitor
On inital power up the display every other line is distorted by what looks like a vertical bars. This problem used to slowly goes away as the monitor warmed up, but not any more. It is constanly is present on both sources. Any help is appreciated.
  • AmirK007 Jun 22, 2011
    Thank you for the tips. I will be checking the Caps this weekend and hopefuly is some thing as simple as cap. The repair cost for this well beyond what I can pay for a new monitor.
    Cheers
    Amir
  • 11,361 Answers
Look for bad caps with domed tops first.
There are more than one versions of the board to get the correct set of caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
Jun 26, 2010 | Gateway FPD2275W LCD Monitor
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Oct 12, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 215TW SyncMaster 21" LCD Monitor Logo
80 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
