Question about HP Pavilion dv2310us Notebook
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
  • 26 Answers
Registry Fragmentation Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks. b> Too Many Programs areInstalled Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs. 1. Click Start ' Control Panel.
2. Click Programs ' Uninstall a Program.
3. Select a program to remove.
4. Click Uninstall button.
5. Follow the wizard.
6. Reboot the computer after completion. b> Insufficient RAM Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required. b> Lack of Proper Configurations You will feel that your computeris slow and freezing if you haven't set Windows for best performance. 1. Right click My Computer.
2. Select Properties.
3. Click Advanced System Settings.
4. Click Advanced tab.
5. Click Settings button under Performance frame.
6. Select the option Adjust for best performance.
7. Click Apply ' OK ' OK. b> Junk Registry Keys Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Posted on Jun 16, 2011
  • 76 Answers
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Posted on Mar 21, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Corrupted System Files
Your computer slows due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer slows.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer crashes due to problems with the computer memory. A faulty RAMmay result in Blue Screen of Death (BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer slows because of apreviously failed or incomplete installation. An incomplete or failedinstallation creates junk registry entries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer slows if the operating system has no adequate free disk space toperform its operations. Temporary files, temporary internet files, log files,browser cache and other files may occupy a large amount of your disk space andthus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
Posted on Jun 24, 2011
  • 153 Answers
Take your computer to a good technician because fading of colors sounds weird to me...
Posted on Jun 21, 2011
    Sergeant:
    Novelist:
  • 164 Answers
If you are experiencing slow response on your computer you may do the following below.
Do a disk clean up to clean unnecessary files on your computer.
To open Disk Cleanup, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup
2. Disable unnecesary windows programs running on the pc
Start > Run > Type services.msc
Look at "Startup Item", and we need to identify the program that we want to disable and click on apply.
Click on close and restart the pc.
3. You may also check if you do have multiple Antiv virus programs cause it would slow down your pc.
4. Run a scan on your computer to check for any malicious software.
5. If you are using IE, delete cookies, temporary files and reset IE if possible.
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
I have a discolouration mark on the screen that I believe was cused by holding a dvd on pause for too long. It has been suggested that I degausse the screen. Can this be done?
depends on what type of tv it is , if its a cathode ray tube tv then yes you can, if its a lcd or plasma then no you cant, you could try a program called pixel protector on the latter two types of tv, this will play white noise continuously on your tv to try to make the pixels rest , there is no guarantee that it will work, but worth a shot at least
Mar 21, 2011 | Acer Televison & Video
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
Dec 14, 2009 | Sony KP-53XBR200 53" Rear Projection...
Hello, I have a problem with my c3200! looks like yellow, and color looks faded. The image I'm trying to print looks all faded. Any help would be great thank you for your time
Try running the gradient/color adjuster (do a full test). It's in Additional Functions screen.
The C3200 series is known for this and many other issues. Most of the customers that I met has since switched to a Xerox color machine that has much better results (Docucolor series for print shop/marketing type work, and the WorkCenter 7600 series for high end office work. Both same body design, different engine/system software)
Nov 25, 2009 | Canon imageRUNNER C3200 Copier
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Color problem please help
Did you just replace the toners? are you using generic? I have seen some colors off due to generic toners, (could be a bad batch).
Also, there should a be screen in the Menu section where you can try adjusting the color or
Re-calibrate it ( I would try this 1st)
Print out a Demo sheet it will give you a color test sheet how does it look?
I am not a color copier specialist but have worked w/techs that are, but i work on color printers, ususally same principle.
Also look for a screen called Configuration page this will tell you the settings of the copier and may actually tell you if a color is off.
the problem is you have to have a service manual because you are dealing with adjustments on an X-Y plane.
Nov 20, 2008 | Office Equipment & Supplies
Monitor problem - Dark colors, slow screen refresh
It sounds to me like the picture tube in the monitor is going out. I began to wonder if it was your video card until you mentioned that you used it with various computers. This tells me it's the monitor itself. Unfortunetly, I think your monitor may be due for retirement.
Oct 22, 2008 | ViewSonic VG900b 19" LCD Monitor
HP Pavilion dv2310us Notebook Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
