Question about Samsung Netbook / Intel Atom Processor / 10.1" Display / 1GB Memory - Ivory (NF210A01)
How do I change my screen resolution to 1024 x768
  • 72 Answers
Right click on any open area on the desktop. Select Screen Resolution if you're using windows 7 or select Options if Windows XP. If windows XP, a window will pop up and you can change the resolution on the last tab.
Posted on Mar 21, 2011
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
Lcd screen of AT3201W is 1366x768. but i m unable to set the same. (now using 1024 x768) please help how can i set the resolution to 1366x768
The problem is the displayadapter.
You could try to find the newer driver - If You could give more specific info what it is and the Operating system too - I could let you know more about it.
In very many cases You need to replace the hardware, because older display adapters (Integrated or not) cannot support wide screen resolutions.
Jan 06, 2011 | Computers & Internet
When i turn my computer on with the normal mode it says it's out of range. how do i fix that?
You need to set the resolution on the PC to native resolution (1024 x768 @60Hz) of your LCD monitor, the resolution was too high for the monitor to display, that is why you get the error message. Start the PC into save mode by hitting F8 key during boot up then reset the resolution to your monitor native resolution and then reboot.
Jan 29, 2010 | X2Gen MG15VT 15" LCD Monitor
Resolution problems with acer mini notebook NEED HELP
First thing I would suggest is going to Windows Update ( Using Internet Explorer ) and downloading the updates. Second thing would be to check and see if your screen is capable of the 1024x768 settings. The manual should tell you. After that let me know what you come up with.
Jun 22, 2009 | AcerView 54EL 15" CRT Monitor
Win XP with Acer LCD" X193w Monitor Display Resolution problem?
First, make sure that it has found you exact monitor, if not install the drivers for the monitor and see if that helps. Also check the specs on the monitor and make sure it can go to the size you are selecting
Apr 21, 2009 | Acer X193W LCD Monitor
Trouble setting up VGA cable to watch movies from my computer on my TV?
First, make sure the VGA cable is plugged into the AV6 slot on the back of the TV.
You will have to go into your computer, and click Start --> Control Panel --> Appearances and Themes --> Display --> Settings and change the screen resolution to 800 x 600 first.
Then go into the program for your Graphics Card and change the screen resolution to 800 x 600 with a 60Hz Refresh Rate - sinc ethis will most likely be a change for you, your computer screen will seem to "flash" a bit - your eyes will adjust as you become used to this.
The other resolutions that work will be the following, but the 60 Hz refresh rate is the key:
Supported Display Resolution•Computer formats: 640 x 48060Hz, 800 x 600 60Hz, 1024 x768 60Hz, 1280 x 720 60Hz•
Feb 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
I need technical support
You need to try what it says try lowering the or color depth try 1024 X768 256 colors if that doesn't work try 800 X 640 256 colors Right Mouse click on the desktop where a Icon isn't go down to properties regular click go to settings change the screen resolution and color depth and color quality to above suggestions apply changes try your movie
Johnlgrn
Dec 27, 2007 | Computers & Internet
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
See all Samsung Netbook / Intel Atom Processor / 10.1" Questions
Samsung Netbook / Intel Atom Processor / 10.1" Display / 1GB Memory - Ivory (NF210A01) Logo
87 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
