Question about Video Game Consoles & Games
My xbox has been working great since christmas but last couple days it's been freezing up & today a red light started flashing. what do i do? Thx
5 Suggested Answers
SOURCE: xbox 360
Unfortunately this is a very touchy situation. There is one home method for curing this problem.
1). Wrap your Xbox 360 Console COMPLETELY with a towel, so you can only see the power button, and the three flashing red lights.
2). Power on your console.
3). Leave for 30-45 minutes.
4). Power off the console.
5). Unwrap the towel from the console.
6). Power on.
**Problem Solved** If not continue reading.
After that you are unfortunately forced to call the dreaded Microsoft Customer Support Line
1-800-4-MY-XBOX
1-800-469-9269
And ask to create a repair order, they will send you a Purolator (or FedEx) shipping box. You have to send your console to them, they will repair it and have it to you within (2-3 business weeks).
Posted on Nov 13, 2007
SOURCE: my xbox 360 not on ,its flash red light
null
Posted on Dec 18, 2007
scanner077
  • 52 Answers
SOURCE: Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Posted on Dec 21, 2008
  • 18 Answers
SOURCE: BEEP THEN FREEZE
You might check out the Informative article atEzinearticles.com to fix the freezing problem as the articlegives the information about a DIY guide, (though i don't remember thename of the site) but you can check the article from http://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369
Posted on Apr 07, 2009
Xbox 360 three red lights occasionally
Dave thanks for your question. It appears that your xbox is experiencing over heating issues. Here is a link to an XBOX 360 repair guide for this issue.
Jan 26, 2013 | Microsoft Xbox 360 Console
XBox completely quit working the day after Christmas. We had purchased Halo Reach and had problems with the game freezing up only minutes into the game. We exchanged the game and it still continued to...
The problem is not with halo; your xbox GPU is losing the connection with the mainboard. This is a common problem, and microsoft faced a class-action lawsuit because of it. Call microsoft tech support; if you're lucky, they'll send you a new console.
Dec 27, 2010 | Microsoft Xbox 360 Console
I got 3 red lights after using it for a couple hours then 2.
My xbox is not working the lights on the start button is flikering & the lights around the center are flashing in a counter clock wise ring?????????????
Mar 02, 2010 | Microsoft Xbox 360 Console
"Key" issue - how to find
So you got the RROD on Christmas day, man that was a good present. The two lights (1 and 3?) usually means the system overheated and it cuts power to the CPU and GPU. If you did the bolts/washer fix, you actually do not want this to occur. You want it to stay on for 30-35 mins or so without doing the two lights (1 and 3). Usually you can do this by cooling the CPU fan and not the GPU. There is a good tutorial for the clamp fix here (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm). It worked for my XBOX 360.
Unfortunately, It sounds like you turned on the XBOX 360 with the DVD drive disconnected. If so, I hate to add to your headaches but your XBOX 360 is probably banned from XBOX live.
If not, there is a good tutorial for replacing your XBOX 360 drive at: http://www.360-hq.com/xbox-tutorials-61.html It also talks about rekeying the drive.
If all else fails, you might trying talking to 360 Pros (http://www.360-pros.com/%28X%281%29S%28oyqpez55tpvpar451buhwgfi%29%29/xbox-360-repair-service.aspx). I know some people who have used their repair server and if you've opened the XBOX 360, you can not use Microsoft.
Jan 01, 2010 | Microsoft Xbox 360 Console
360 lock up/Freeze
that isnt normal if it says disc is unreadable look at your discclosley and check for a ring if it freezes well theres no doubt about it your xbox is ****
Apr 16, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 2 red lights and when i turn it on, it only lasts minutes until the red lights appear
its called the red ring of death and it means ur xbox is breaking my friend didnt no this and got the red 3 times and now his xbox wont work let it chill for a couple of days idk if this will work but hopefully it will
Mar 08, 2009 | Microsoft Xbox 360 Console
Hi there!
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
Dec 13, 2007 | Microsoft Xbox 360 Console
XBox 360 freezing- Not what you think
Your system is headed for the dreaded red ring w/ three red rings. My system started doing the same thing just before this happend. If you have a service plan with it i would suggest returning it and getting a new one.
I tried all the there little tricks as well deleted everything off my harddrive all that good stuff i think it made mine worse. Cuz after all that i turned it back on and bam three red lights and no picture or sound.
Nov 28, 2007 | Microsoft Xbox 360 Console
Xbox 360
6). Power on.
1-800-4-MY-XBOX
1-800-469-9269
Nov 13, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
