Question about Digidesign Mbox 2 Barebone
The mic and 1/4 inputs are not working properly. everytime i plug in my bass or mic i'm getting static
    Problem Solver:
  • 14 Answers
You have a bad A/D converter. Maybe it can be replaced, but these units are pretty cheap, and may exceed the time to research and repair. Digidesign was bought out by Avid, and they may not support the unit if you're not the original buyer.
Posted on Mar 21, 2011
On my Accustic B30 bass amp the input jack is not working. Can this be easily fixed?
Have you checked the battery? Put a brand new one, if that's not the problem, take it to a reputable tech.
Jul 22, 2017 | Bass Music
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
Apr 27, 2014 | M-Audio Audio Players & Recorders
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
Brand new ag30 when I plug my mic sm58 into it all I get is static no sound as in singing comes through it I'm using a XLR to quarter brand new lead.. Have tried everything when I hit the tip of mic sound...
You should be using XLR to XLR cable, NOT a 1/4 inch cable. There is a problem of the 1/4 inch being the unbalanced version and is not compatible with this unit's input.
Use the XLR to XLR mic cable and it will work fine.
The cable you have would work for one of those cheap Karaoke machines...
Mar 25, 2011 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
How to connect it to computer mic input
Instead of using the mic input on your soundcard try using the auxiliary input. You will need a cord that converts from 1/4" mono to 1/8" stereo. That cord goes from out on your pedal to aux in on your computer. Use whatever you need to go to the input of the pedal.
May 31, 2010 | Behringer Bdi21 Bass V Tone Modeling Pre...
HP Pavilion 6704nr laptop, can't plug bass guitar
you sould instal the proper driver(for XP) for the sound card,before that check in my computer-advanced-device manager- if the driver is working properly.
Dec 08, 2009 | HP (153147-001) Sound Card
Mic not working
be sure that u have selected the correct input device in audio manager and u have plugged in a working mic properly...
if its still not working open ur input manager of ur audio device and select the input mode over der to a normal 1 not 5.1 channel then mic would work
Aug 31, 2008 | Intel DG965RY Motherboard
No recording?
GarageBand on Windows makes your music move everywhere, and now you're able to utilize GarageBand to get Laptop/PC. With live Applications, it makes it effortless to get more pleasure in creating music like DJ by triggering loops and audio effects in real time plus GarageBand free Application allows you to do things that you can never perform on a true instrument. GarageBand For PC Download GarageBand For Windows Mac
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
Dec 01, 2007 | Panasonic PV-GS250 Mini DV Digital...
Problem with MixerInputs
I have pretty much the same setup, as in snare and bass into the xlrs. You can change the physical jumper positions on the sound card, to give you a lower gain, as in mic/line (details in the manual) This lowers the input gain. Unfortunately, this can sometimes be too low. It's one or the other.
Sep 18, 2007 | M-Audio Delta 1010LT Sound Sound Card
Digidesign Mbox  2 Barebone Logo
158 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
