Question about Maytag MSD2651 HE Side by Side Refrigerator
Our refer isnt running. Freezer is getting iced up around coils on back wall near the bottom. When I take a heat gun to it and remove all the ice, fridge works again until freeze up reocurrs. Seems we may need a relacement heating element or somthing like that??
    Guru:
  • 1,524 Answers
Possible heating element, limit switch, or timer.
Posted on Mar 21, 2011
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Bottom of Kenmore freezer vents icing up. Did test recommended weeks ago, replaced defrost timer. Worked fine for a few weeks and now is back to icing up and fridge not cool at all. Melted ice again with...
If the timer didn't fix your problem, and it sounds like it didn't, then there are 2 other components to a defrost system. The defrost heater, and the defrost thermostat. Both are located around evaporator. Back inside wall of freezer will have to be removed to access these parts. Thermostat will be clipped near top of evaporator coil. Heater will be near bottom of coil.
Sep 15, 2017 | Refrigerators
GE Profile Side by Side PCF25PGTAWW Ice maker started to leak inside several weeks ago. Ice column formed inside back of freezer and on shelves. Removed ice and turned off ice maker. Refer and freezer...
when you removed the back panel if you look on the right side you'll see a round coil next to the fan you have to clean that out at least once a year,if you get a shop vac you can vac off the coil and then set it to blow and blow the coil out to clean it,if your food is staying clod you don't have a problem,when the machine goes into defrost there's a heater in the freezer that melts the ice off of the coil,when it comes on the temp will get warmer for like a half hour or so until it comes out of defrost and starts to cool again.hope this helps
Oct 05, 2017 | GE Refrigerators
Freezer fan is making a strong noise as if it was not functioning properly
Hi!!
The evaporator coil is probably covered with ice, before fan gets damaged, unplug unit from wall outlet, remove freezer back panel (where the fan is) and using a heat gun or hair dryer, melt all the build up ice, make sure the air duct is clear of ice also. When finished, replace back panel and plug unit back on. Check temp. settings, lower freezer setting by 1 click.
Don't forget to rate this post!! Good Luck!!
Jul 12, 2010 | Refrigerators
Westinghouse silhouette frost free 522 fridge is not cooling properly top and bottom.freezer fan is still working,and the motor at the bottom in the back of fridge stay's constantly running and has done...
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Jan 01, 2010 | Westinghouse Refrigerators
Bottom freezer constantly runs till it ices up.
check coils on bottom of box and clean out with air or coil brush
Aug 09, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Refrigerator not cooling
unplug appliance, melt ice on back of freezer, remove panel rear of freezer, find leads to defrost heater and test with a multimeter, if you have condinuity replace defrost termostat, if no condinuity replace defrost heater. after removing panel you will have to melt ice in rear with heat gun before testing.
Jun 22, 2009 | Admiral Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Maytag MSD2651 HE Side by Side Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
