Question about VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD)
How can I boost the signal strength of vx610 cdma verizon terminal.
I need to unlock my moto g boost mobile and I need the unlock codes please.
Boost Mobile Moto Gis CDMA only. CDMA phones don't take SIM cards, and the only unlock available is bootloader unlock via Motorola's website. If your country doesn't have CDMA carriers, don't buy the Boost Mobile, US Cellular, or Verizon Moto G, unless you plan on using it on Wi-Fi only
Apr 22, 2016 | Cell Phones
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
RAM CHKSUM ERROR ON VX610 TERMINAL I : commsvr. out Any Idea what is the issue. When I press F4 it say system error call customer service
Maybe you have a corrupted softpay system, call you credir processor to reload it. An secondly your GPRS/Radio board maybe bad too. Call (775)358-2922 look for randy maybe we can help. thanks
Nov 12, 2011 | VeriFone VX 610 Credit Card Terminal...
Hi. i own a verifone vx610 wireless credit card machine and I'm getting the TAMPER message on the screen. is there anyway the fix this problem. thank you
if you still need help with your Vx 610 we can help you call (775) 358-2922 ask for Randy and YES we can fix the TAMPER error. Thanks
Jul 15, 2011 | VeriFone VX 610 Credit Card Terminal...
Is there a reset botton ? if so where is it?
there is no reset button in your VX610. May i ask what do you want to reset your unit. If you still need help you can call (775)358-2922 and askfor Randy. Thanks
Jul 08, 2011 | VeriFone VX 610 Credit Card Terminal...
I have a verifone vx610. I need to change the sim card. I have looked at the online pdf and the instructions and pictures don't match up to what I have. When I removed the sled from the bottom of the...
You may or may not be looking at a GPRS modem (which require a SIM to operate) for your Verifone Vx610 . It could be a CDMA modem instead. To tell the difference (as long as the labels haven't been removed), simply look at the outside of the modem (you don't even need to remove that Phillips head screw and remove the modem from the terminal). You're looking for up to three labels: One is S/N:XXX-XXX-XXX and a barcode - does it read Sierra EVDO? A second one is CDMA-1.67-VZW-P1 act deact act The third one is ESN HEX:1234ABCD (8 alphanumeric characters) and ESN DEC:12345678910 If any one of these is true, it's CDMA and does not use a SIM. If none of these is true
Apr 01, 2011 | VeriFone VX510
I need a download for an operations manual for a verifone vx610
The link below should be what you need.
http://office.manualsonline.com/manuals/mfg/verifone/vx_610.html
Mar 17, 2011 | VeriFone VX 610 Credit Card Terminal...
My boost sim card don't work in a t-mobile phone
you are correct.Boost is owned by Sprint which uses CDMA to provide cellular service and T-mobile uses GSM. The 2 will never work,but you may be able to get it to work in a Verizon phone they use CDMA also
Jan 15, 2010 | Cell Phones
VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD) Logo
243 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
