Question about Jabra GN9125 Wireless Headset
Hello, my Jabra GN9120/GN9125 won't work on my AVAYA 5420. It was working fine then suddenly stopped. I purchased a new one and paired it. It still won't work?
4 Suggested Answers
  • 5 Answers
SOURCE: problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Posted on Feb 01, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Posted on Aug 23, 2008
SOURCE: hello, i cannot pair my jabra
To get the Jabra SP5050 into pairing mode: Start with the unit turned off Press and hold the answer/end button Hold until the light starts blinking constantly, without pauses Release the button - this is pairing mode Your phone should be able to "find" it when it's in this mode.
Posted on May 17, 2011
Will these headsets work with a VOIP phone system as we are moving from ISDN to VOIP
neil look at the manual and check the voip phone model number against the most common phone types it works with
https://www.jabra.com/~/media/Product%20Documentation/Jabra%20GN9120%20Series/User%20Manuals/User_Manual_Jabra_GN9120-GN9125_EN.pdf
ISDN is a digital system are you using the old phones on the voip or having to install different phones ?
Nov 30, 2015 | Jabra GN9120 Wireless Headset
Gn9120 cisco 7941
I had a 9120 for years, great headset. Change the compatibility wheel and levels on the unit per the instruction book link below. https://www.jabra.com/_/media/Product-Documentation/Jabra-GN9120-Series/User-Manuals/User_Manual_Jabra_GN9120-GN9125_EN.pdf
Mar 01, 2018 | GN Netcom Radio Communications
I purchased a new Iphone and my Jabra will not pair. I removed the Jabrsa connection from my old iphone and the Jabra still will not connect. How to reset Jabra and pair new phone?
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Nov 12, 2010 | Jabra Cruiser InCar Speakerphone Black
Jabra 2080 won't connect. Blue light flashes constantly.
I apologize you having trouble with your Jabra Blue tooth Headset.
The reason why its flashing is because it has not paired with a device or the battery may be low.
1. Take the battery out of the unit to fully reset the unit.
2. Put the battery back in the unit "turn the unit on"
3. Try using the code 0000 this is the default code to pair the headset with your hand set.
If the above steps does not work it might be because of a low battery, Thus I would recommend purchasing a new battery for it then try the steps above again.
Again we apologize your having issues with your headset, if you have any further questions please get back with me.
Thanks for using Fixya.com
Oct 28, 2010 | Jabra Bluetooth Headset with Adjustable...
I cannot pair the headset with my blackberry everything was fine till 2 days back, but suddenly it doesnt work
unpower headset mains and replugged and let it go through its reset set up should be ok after that
Oct 30, 2009 | Jabra Bluetooth Headset with Adjustable...
Avaya 5420 phone system
There is a problem with the trunks. A phone line could be bad, a line (PRI/T1) could be dead....
Jul 02, 2009 | Avaya - IPO-56/5400 SETS(IU).IP PHONE 5420...
It's connected fine, now it won't connect, what's up? Jabra BT350
Delete the problem unit off the phone's list then turn the phone off then back on. Next you will have to go through the pairing procedure for the headset again.
Mar 24, 2009 | Jabra BT350 Bluetooth Headset Headset
My GN9120 does not connect ...
I solved this over the weekend: I found out, that the GN9120 comes with slightly differing battery sizes. I had to push the contacts deeper inside the housing so they got in touch with the new battery again. I used a very small flat screwdriver to achieve that. You have to be careful not to destroy anything surrounding.
This was an easy solution to a stuoid problem, but the contacts are barely visible in the inside of the GN9120 so i needs to have the idea to search for that as the source of trouble,
Jan 16, 2009 | Jabra GN 9120 Midi-boom Microphone-Headset...
Jabra bt500
yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
Jan 04, 2008 | Jabra BT500 Wireless Headset
Jabra GN9125 Wireless Headset Logo
165 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
