Question about GE Refrigerators
The controls for temperature are no longer light up it's a GE pds22sisarss. Any suggestion
  • kdm6 Mar 22, 2011
    If I unplug controls light up for 20 minutes and then clicking sounds starts lights go out then 30 minutes later clicking stops. But everything is cold and ice is still being made.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You will need to replace your motherboard. It is located in the rear of the refrigerator under the metal plate.
Kelly
Posted on Mar 21, 2011
  • Smitty Mar 22, 2011
    Replace the board and you will be in good shape.
13.7 GE Freezer (FUF14SVERWW). high temp. light on. Control panel functions, fan motor OK, temp. sensor iOK. replaced capacitor/control relay still no freezing. Can it be the compressor? Suggestions
Is the compressor running .if yes do you feel any temperature difference on the 2 copper lines. Sometimes compressor would sound like it running but piston is broken and it would not compress.
Jun 27, 2018 | GE Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
May 14, 2017 | GE 30" Built-In Single Electric Wall Oven...
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
We have a gsh25jftfww ge fridge. the temperature control panel (on front) does not light or work and fridge and freezer is not cooling. The light is still on in the refridgerator, but fan is not running...
Your refrig uses a main control board that is on a recall list .The board uses a WR55X10552 . The replacement board is WR55X10656 . I would suggest calling GE factory service and they will cover this under warrenty , due to the recall .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
OVERHEATING OVEN
Sounds like the thermocouple needs replaced. A continuity check when cold might look good. I suggest replacing it.
Mar 26, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
