Question about Philips 64P8341 64" Rear Projection Television
Philips 64P8341 64 in
Piicture fuzzy,whites too bright ,tryed adjusting picture,brightness
  • mikes753 Dec 15, 2008
    White's are too bright, anything bright in color has a fuzzy ring around it. Please Help
  • 60 Answers
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Posted on Mar 13, 2009
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
My Philips HDTV 60pp9202/17f chassis: DPTV305F picture has problems. It appears "fuzzy" and "cloudy". I've tried to go to picture options and adjust the tint,sharp,brightness, etc.. and havn't come to the...
Thats indicating that the coolant in the three CRT's need replacement. The phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Aug 09, 2010 | Televison & Video
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Picture too bright to see screen properly
try to use the tv remote to adjust the brightness, tint, and color
Apr 19, 2009 | Nintendo Wii Console
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Its a slight possibility that a 2.00 Part called a capacitor could be bad on the screen drive voltage source. But most likly it sounds like the Picture tubes are comming to the end of there life expectancy. If the crts are weak there is a crt rejuvinator that could possibly clean the grids off each color gun. But this is a crap shoot, as sometimes it destroys the tubes. These type of repairs are not for the handi-man or a consumer to do. There are no real user replaceable parts inside so unless your able to solder and know the HI Voltage saftey issues, you should call a pro to assist you in this repair. Good Luck
Jun 24, 2006 | Philips 9P6031C 60" Rear Projection...
Philips 64P8341 64" Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
