When computer boots a message comes up..windows could not start successfully a recent hardware or software change might have caused this.. etc. I tried to boot in safe mode but the whole start up process starts all over again repeatedly
    Novelist:
  • 202 Answers
Just take the windows xp cd boot through CD drive and repair windows xp or else format full c drive and install freshly
Posted on Aug 03, 2008
Hp black screen
Computer black screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive , It also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer black screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can be used to burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are a lot of software for you to use,Windows Boot Geniusowns a better performance among such kinds of software I've used. It is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.
Source:
http://www.windowspasswordsrecovery.com/windows-boot/
Mar 21, 2013 | HP Pavilion Computers & Internet
Bsod
Computer blue screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive . They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software such as TenorshareWindows Boot Genius. It owns a better performance among all kinds of software I've used. Windows Boot Genius is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.It is as easy as three steps to fix your computer by use the software:Step 1. Create a bootable usb or cd by this software
Step 2.Set your computer boot from CD or usb flash drive
Step 3.Fix computer blue screen after running up Windows Boot Genius
By the way,reinstall your operating system can also help you out if nothing important stores in it.
http://www.windowspasswordsrecovery.com/fix-windows/blue-screen-of-death.html
Mar 03, 2013 | Acer Aspire Computers & Internet
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or...
did you recently install a new hardware ?
did you recently install a new software?
if you answered yes to any of these questions above you need remove it.
therefore if you installed a new hardware safely shut down and remove cables and remove hardware.( if it is hardware the hardware is not compatible with windows)
if it a software boot in safe mood then uninstall software. ( to boot in safe mood, press F8 while computer in turned on )
Sep 27, 2010 | NEC VALUESTAR T (VT900/8D) PC Desktop
I had to reboot my Eee PC; however, now a message comes up statting the following: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might...
If you added any exta hardware means kindly remove it and boot the computer
Then you try boot by selecting the option of Boot using last known good configuration.
If the boot is successful then you can boot later booting without any problem.
If boot is not successful and this problem is happened after installing any software or driver software means boot in safe mode by pressing f8 key and uninstall it
Mar 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My acer ast650 refuses to start, it boots up goes to this blue screen where it shows del and f12. it then goes to another window that displays black a message comes up saying that windows did not start...
Try booting into safe mode, it should give you
that option, if it doesn't boot then, you'll
have to do a fresh install of windows,as
your system files ergo, boot.cfg have
been corrupted...
Oct 15, 2009 | Computers & Internet
Windows failed to start.a recent hardware or software change migh
sounds like a driver issue. Boot to safe mode and do a system restore..you may also get lucky by booting into "last known good configuration" good luck!
Jun 03, 2009 | Microsoft Windows? Vista Home Premium...
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
