I need replacement belts for a Realistic CTR-51
  • Audio Player... Master
  • 5,515 Answers
Generally all you need do is measure the diameter of the old belt(s) in mm and type "cassette drive belt ??MM" into google. You don't have to be spot on with the measurements either.
Posted on Apr 22, 2011
How many belts does a Realistic 14-972 909B tape recorder need?
You can try this site that I am listing but if it is not in stock, then you can use the dimensions listed to see if you can find one. SMC ELECTRONICS
Dec 13, 2017 | Radio Shack Audio Players & Recorders
When was my realistic ctr-66 tape recorder manufactured?
Here is a link to some support information from Radio Shack for your model:
http://support.radioshack.com/support_audio/8258.htm
The dates on the documents seem to indicate that mid to late-1994 was the manufacture date.
Sep 03, 2014 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Need a new mic for TRC447 radio Shack CB. Has a 6 pin connector
Hi Old
here is the link to wire up a different mic look on pg. 51 of this pdf.
link.http://www.cbtricks.com/radios/realistic/trc_447/graphics/trc_447_sm.pdf
hope this helps save this radio from the trash!!!
Ray
Aug 05, 2010 | Radio Shack TRC-447 CB Radio
Need assitance for vw repair
You are probably right, the clearance between the pistons and the valves is very tight on the 16 valve engines. one of the valves may have hit a piston., or even worse bent a rod or damaged the crank.
I would run a compression check, or leakdown check before pulling the head. I have a service manual for 90-93 Passats w/ 9A 16 valve engines. the manual says compression should be 145-189 psi. limit 109 psi w/ 44 psi max difference between cyclinders.
On these engines you also need to check that the timing on both cams is ok.
Apr 16, 2009 | 1984 Volkswagen Scirocco
I need a parts list for an old realistic ctr-56 cassette tape recorder the drive belt needs replaced it melted
Hi 1George I found a replacement belt that works but not an exact replacement. P/N FRM9.6 Flat belt from Gateway electonic in St. Louis Mo. BUT you may have to try and order it from the manufacture www.russellind.com as I had to sort thru a bunch of belts to find this one. It works great. more info. e-mail sales@russellind.com bar code # 3152-00129 Good LUCK tedglow@charter.net
Aug 17, 2008 | Audio Players & Recorders
Tape Deck Belt Replacement
i dont have the model #, give me the model will try getting the picture.
Jul 16, 2008 | Audio Players & Recorders
Can't release tape from CTR-121
How much warranty you have left on that product. It sounds as if you need to get that replaced. Or You need a new button. something may be broken off inside the machine.
Dec 12, 2007 | Radio Shack CTR-121
141 people viewed this question
 Grubhead
Grubhead
