Question about Nova Development Photo Explosion Deluxe for PC
When I try to save a project, I get"photo explosion has quit working". It doesn't save and goes back to project studio opening. I run windows 7. I have uninstalled and reinstalled Photo Exp'n Deluxe version 4; but get the same error message.. Please help.. It is very frustrating.. Constance Hislop cbhislop@comcast.net
  • 2,632 Answers
Welcome to Fixya. Have you tried running the software in Compatibility Mode? Depending on your version of Windows 7, you may have the ability to run it in Compatibility Mode. Try right-clicking on the Photo Explosion shortcut that is on your Desktop. Then, go to Properties from the pop-up menu. Then, select the Compatibility tab. On that tab, put a check next to "Run the program in compatibility mode for:". Then, select Windows XP SP2. Click on the OK button to save this setting. Finally, try launching the program again.
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 21, 2011
EVERYTIME I TRY TO OPEN PHOTO EXPLOSION LATELY I RECEIVE THIS MESSAGE.....ENCOUNTERED A PROBLEM AND NEEDS TO CLOSE. WHAT CAN I DO.
This problem can occur for any software not only this. It can be due to file corruption.
Once the files are corrupted or deleted from your PC or Laptop then the particular software wont be able to run properly and while running the program it show error message.
So a solution to this is re-installing the software ..That will help you. If there are some saved files then before re installing try to back up ..
Thanks..
May 20, 2011 | Nova Development Photo Explosion Deluxe...
Photo explotion will not open after i use it one time. i have to uninstall and reinstall it to use it,it worked fine with windows vista but i now have windows 7
Mar 13, 2011 | Nova Development Photo Explosion Deluxe...
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Nov 11, 2010 | OnDemand Photo Explosion Deluxe 2.0 for PC
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
Photo explosion 4.0 project studio. When I create
I kind of doubt this is your problem, but try and save the file by using the "save by a different name option." Then click options and slide the file size to large. Make sure you have your color setting set to rbg, not cymk. The channel should be set to 8 bits, not 16. I am not sure where that selection would be made in 4.0, but jpgs are not compatible with 16 bit channel. If you can't find the setting, check the help file.
Two questions: 1 Can you open any pdf and jpg files in Photo explosion, and 2 can you open the files you have created in photo explosion in another program?
If you can't open any jpgs/pdfs with any program, the problem is probably with your operating system. If the problem is only with photo explosion created files, and they can't be opened in any other program, it may be the "plug in." That is the piece of software required to produce the file. A viewer is also required. If you can open the jpg in another program, that would indicate photo explosion. The plugins that are loaded into the program should be listed, possibly under tools. You can try to update/reload these.
You have not indicated your operating system. This is important to correctly answer more complicated issues. For instance, if you have Vista 32/64 bit, your software has to be compatible and set to the right version. Because Vista is prevalent, I looked to see if it is compatible. Unfortunately, Nova recommended buying an update for the 32 bit version and had no info on the 64 bit. Somewhere on the photo explosion box there should be a small label telling you what it is compatible with. I hope that if this was not helpful you will leave me more info and answers to the above by writing a comment. I can get back to you with more specific advice.
May 06, 2010 | Nova Development Photo Explosion Deluxe...
Is there a program out there like Greetings 99 for vista?
Art Explosion Greeting Card Factory Deluxe 7.0 - This version of Greeting Card Factory from Nova Development adds another 10,000 graphics (90,000+) and almost double the number of project templates from earlier versions (24,000+). Create all kinds of projects from greeting cards and calendars to stationery and certificates. Some of the kinds of cards include Thank You notes, Pop-Up Cards, Note Cards, and Photo CD Greeting Cards. Helpful tools: Photo Editor, Card Browser, and Drag and Drop Text Effects. It's also Windows Vista certified. This is a very good program and works with Vista. Hope this helps you.
Aug 23, 2009 | Microsoft Graphics Studio Greetings 99...
Can't install disk 2 for photo explosion deluxe 3.0
Does it appear to be loading anything from the sisk or does it just turn the access light on and do nothing? It could be the second disk is damaged. Check the back side of the disk for a fingerprint mark or scrathches. clean off the priint and try again.
Does the disk read ok in File Explorer, try opening a file and see if it can at least access the disk dont matter if it cantb open the file because it doiesnt have a program that can open it, you are just checking the readability!
Jun 23, 2009 | Nova Development Photo Explosion Deluxe...
My photo explosion deluxe in windows xp does not run on vista
According to their website: http://www.novadevelopment.com/Products/us/prw/sys_req.aspx, pdw works with vista. Can you tell me what exact error you are getting?
Jan 02, 2009 | Nova Development Photo Explosion Deluxe...
Photo Explosion 3 won't save images on Vista equipped computer
Doublecheck where it's trying to save the photo to. Vista gets a little weird about rights and folders, especially if UAC (user account control - Vista's idea of the "ultimate" security system)
Just for chucks, try and save the edited photo to someplace like the Users "My Documents" or desktop, where you should have full rights. If it saves there, see if you can change options to always store there.
And, I love your pipe tobacco :)....
Jul 19, 2008 | Nova Development Photo Explosion Deluxe...
Nova Development Photo Explosion Deluxe for PC Logo
153 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
Martin Murray
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
