Question about Emerson EWR20V4 DVD Recorder/VCR
I've had this unit ewr20v4 for about 5 years, never tried to copy from vhs to dvd until now. I get error message, unable to copy to this disk. called CS they offered an upgrade disc but will charge me 23.00. from reading online complaints Im not sure this will fix it. Not sure this is worth the 23.00.
    Problem Solver:
  • 14 Answers
You have a VHS that uses copy protection. Your unit is designed for copying self-authored DVDs, like you make from iMovie or another app, to VHS. It won't work with commercial VHS tapes with copy protection. The upgrade is probably a decoder circuit, and may be worth it if you plan to use your unit this way often.
Posted on Mar 21, 2011
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
I was transferring a vhs tape onto dvd and an error message came up stating that the dvd I was using was dirty or stratched (it was brand new!) so i tried another disk and got that it was not suitable for...
plz try by using a dvd lens cleaner, if the problem is not solved then try by changing the dvd data cable, if the problem is not solved, try by reinstalling the burning software if every thing fails then you have to buy a new dvd rom
Jul 08, 2008 | Panasonic Televison & Video
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Will not copy vhs to dvd
I had the same problem. What I had to do was press the 'dubbing' button on the remote while in VCR mode.
Dec 27, 2008 | Televison & Video
Copying my vhs movies to vhs
I find that after 2 years of using my Sima CT-200 GoDVD that I can no longer recored movies from my DVR player. I get an error saying copywrite and shuts off my DVD about 30 seconds later
Sep 24, 2008 | Sima GoDVD CT2 Copy Master Digital Video...
Panasonic dmr-eh75v dvd won't work
dirty lens, broken ribbon connections or adjust the bias of the lens place at the back of the lens.....
May 08, 2008 | Televison & Video
Operating unit
This unit will not record certain types of TV and no copy-protected VHS and it doesn't tell you when you have those situations--and it doesn't come up with an error message that tells you what you are doing wrong. First step is to be sure that your source material is not copy-protected.
Jan 04, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
Mar 06, 2007 | Sylvania SRDV495
Emerson EWR20V4 DVD Recorder/VCR Logo
129 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
