Question about Rowenta DG-980 Iron
Rowenta Iron DG-980 problem
When I turned on the iron this morning, It shot alot of brown water staining my clothes and after this I cleaned it , put more water in the tank and turned it on again but the blinking green light does not stop and the iron starts putting out a lot of steam just on the rest stand , until all the water in the tank is gone. I turned it off and tried again and the same problem. What should I do next. ?  Hope it is not broken because I really need it.  Please Help.  Thanks , L.Abreu.
    Scholar:
  • 70 Answers
Very odd to have brown (rust from household pipes) as your DG980 has brass, stainless and aluminum, so deposits would be white. Make sure you flush and clean steamer tank and reservoir with clear filtered or drinking water only. When final ironing job is at or near completion, pull the reservoir and hold the burst of steam button several times to purge the system of water until no more steam when red light comes on telling you it is out of water. Let cool for couple hours, and unscrew tank plug cover and screw...bring over to kitchen sink. I have a filtered water faucet that I fill and swish around in the tank and then shake out several times as dry as possible. I leave the cover off, the blue reservoir empty, so last bits of water evaporate out. Put it all back together, ready for next use. After 3 or 4 cycles of this use, clean, store routine the iron should be clean. This is painless and costs nothing but a little care. Do not use vinegar or anything else and you should be fine. The deposits will slowly be purged if you use clear filtered water only.
Posted on Jun 13, 2010
  • 594 Answers
You should have a controll or button on the iron that tells it to release the steam. make sure that the button or controll is not stuck.
Posted on Aug 03, 2008
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
Bottom of iron has scale build up
Sounds like you need to clean the iron. Try equal parts of white vinegar and distilled water. Fill the reservoir with the mixture, turn iron to highest setting and place the tron on a wire rack in a baking pan lined with ab old towel. Repeat if needed, Rinse iron with a cycle pf distulled water. Clean iron in a ventillated area since vinegar odor will be strong.
May 27, 2012 | Rowenta DG-980 Iron
Rust colored steam that stains clothing ironed
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 22, 2011 | Rowenta DZ1700 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
I use distilled water in my Roweta. When ironing a white shirt this morning, brown water came out and stained the shirt. What could have caused this and what can I do in the future to avoid this?
Brown water and white scale are often the result of the water you use in the iron...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Jan 22, 2011 | Rowenta DX6700 Iron
Brown water staining clothes when ironing
either the water has sat in the iron too long between uses
or its the iron in the water you use.
you will have to flush out the old water.
try distilled water
Jun 27, 2009 | Rowenta DX6700 Iron
How to clean iron
You can clean inside iron by open the cover and used brush
Jun 26, 2009 | Rowenta DG-980 Iron
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I...
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
May 06, 2008 | Rowenta DG-980 Iron
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
385 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
