Question about Northstar Garden
Model 157550b with a TH3000 pump need to get a inlet manifold
2 Suggested Answers
  • 4 Answers
SOURCE: need to remove inlet manifold on my nissan gtir pulsar(sr20det)
Get some spanners out and take the bolts out!
Posted on May 21, 2009
What kind of oil does a northstar model # 157550b take
THATS A HONDA ENGINE , SO IT TAKES Honda 08207?10W30 IN THE ENGINE AND STRAIGHT 30 WT NON DETERGENT IN THE PUMP OR YOU CAN BUY IT RIGHT FROM NORTHERN PUMPS SUPPLY AS WELL
ALLWAYS CK PUMP OIL WHEN FILLING GAS TANK AS SOME MINOR OIL LOSS IS NORMAL ON USED PUMPS AND IF OIL BECOMES WHITE LIKE MILK THEN IT NEEDS REPLACED RIGHT AWAY (WATER CONTAMINATION ) IF OIL USE GOES OVER 1 QT FOR EVERY 12 HRS OF USE THEN PUMP NEEDS REBUILT
Nov 11, 2015 | Cars & Trucks
Can you hook both heater hoses to the intake i put a 85 chevy 350 in it no were to hook on water pump
One exits the thermostat housing and the other needs to enter at a different point, usually the water pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Nov 04, 2015 | Cars & Trucks
How do i change the thermostat on a '02 rodeo V6?
Hi, you have to start by removing the fuel pump fuse and start car, when it dies try to start again, no more spluttering just cranking, the fuel system is now depressurised. You can now disconnect both of the quick disconnect fuel lines at rear lower section of inlet manifold this is hard to get to some access this by removing the EGR valve so you can get your arms down there watch out for sharp edges of manifold. You dont need to take the top section of the inlet manifold off but will need new lower inlet manifold gaskets to head. Once manifold is off block all intake ports with rag or put tape over ports to stop dirt and stuff falling into ports while continuing to work on the coolant pipes below to get to thermostat. Undo only 4 long centre bolts and the 4 nuts, one in each corner(no.3 in picture).
May 30, 2011 | 2002 Isuzu Rodeo
I need to replace the thermostat for my 2000 Isuzu Rodeo, V6 3.2 Liter LS model? I see that it is on top of the engine under the intake. What steps do I take to remove the intake. Will the top and bottom...
remove fuel pump fuse and start car when it dies try to start again, no more spluttering just cranking, the fuel system is now depressurised. you can now disconnect both of the quick disconnect fuel lines at rear lower section of inlet manifold this is hard to get to some access this by removing the EGR valve so you can get your arms down there watch out for sharp edges of manifold. you dont need to take the top section of the inlet manifold off but will need new lower inlet manifold gaskets to haed.once manifold is off block all intake ports with rag or put tape over ports to stop dirt and stuff falling into ports while continuing to work on the coolant pipes below to get to thermostat.undo only 4 long centre bolts and the 4 nuts, one in each corner(no.3 in picture).
stevenhurc_7.jpgyou dont need to remove throttle body but some people do.
Feb 21, 2011 | 2000 Isuzu Rodeo
Need to remove the water pump
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
WATER PUMP REMOVAL
  1. REMOVE RH ENGINE UNDER COVER
  2. DRAIN ENGINE COOLANT
  3. REMOVE GENERATOR (See page CH-8)
91329747
  1. REMOVE INTAKE MANIFOLD STAY
  1. REMOVE WATER INLET PIPE
(a) Disconnect the following hoses: 91329748
(1) Water inlet hose (2) Heater inlet hose (3) Water bypass hose 91329749
(b) Remove the bolt, water inlet pipe and 0-ring.
  1. REMOVE OIL DIPSTICK GUIDE AND GENERATOR ADJUSTING BAR
(a) Remove the oil dipstick. (b) Remove the mounting bolt of the dipstick guide clamp and generator adjusting bar. 91329750
(c) Pull out the dipstick guide. Plug the guide installation hole of the oil pump. (d) Remove the 0-ring from the dipstick guide. 91329751
  1. REMOVE WATER PUMP
    • Remove the bolt, 2 nuts and water pump.
Jan 02, 2011 | 1992 Toyota Tercel
Water is leaking from inlet/outlet area. is that a heat exchanger problem?
If there is a water leak in between the pool/spa plumbing and the inlet/outlet manifold, it just needs a new gasket if it is a plastic manifold, and if it is a cast iron manifold, the 2" threads for inlet and outlet need to be unthreaded, then coated with a pipe sealant (non-teflon) then rethreaded.
If this leak is in between the outer and inner inlet/outlet manifold peices, then a new gasket is needed. The part number for that gasket is: 006713f.
If the leak is coming from inside the cabinet and leaking down the interior or exterior, it could be a heat exchanger issue.
The most likely event is that the o-ring that seals the header manifold is worn and needs to be replaced.
This would take about 30 minutes of labor and an o-ring.
Please vote positively if this has helped.
Nov 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Location of thermostat on 2002 olds alero 2.2
Thermostat Removal & Installation 2.2L Engine To Remove:
  1. Remove the exhaust manifold. If equipped with an automatic transmission.
  2. Drain the cooling system.
  3. Remove or disconnect the following: chevy_cav_02-04_tstat.gif
    • Thermostat housing to water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    • Thermostat housing to water pump feed pipe.
    • Thermostat.
To Install:
  1. Install or connect the following:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt.
      1. Tighten bolt to 89 in lbs (10 Nm).
    • Exhaust manifold if equipped with an automatic transmission.
  2. Fill the cooling system.
2.4L Engine To Remove:
  1. Drain the cooling system.
  2. Remove the exhaust manifold heat shield.
  3. Remove the coolant inlet housing mounting bolts through the exhaust manifold.
  4. Raise and safely support the vehicle.
  5. Remove the coolant inlet housing stud from the oil pan.
  6. Remove wheel and tire assembly.
  7. Remove the engine splash shield.
  8. Remove the mounting bolts from the transaxle-to-engine block support. Remove the support.
  9. Remove the coolant housing pipe.
  10. Remove the thermostat.
  11. Clean the mating surfaces.
To Install:
  1. Install the thermostat.
  2. Install the coolant housing pipe.
  3. Install and secure the transaxle support-to-engine block mounting bolts.
  4. Install the engine splash shield.
  5. Install the wheel and tire assembly.
  6. Install the coolant inlet housing stud to the oil pan.
    • Tighten to 19 ft lb (26 Nm).
  7. Lower the vehicle.
  8. Install the coolant inlet housing bolts through the exhaust manifold.
    • Tighten the coolant inlet housing bolts to 10 ft lb (14 Nm).
  9. Install the exhaust manifold heat shield.
  10. Fill the cooling system.
  11. Inspect the system for leaks.
3.4L Engine To Remove:
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat.
To Install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts.
    • Tighten the thermostat housing bolts to 18 ft lb (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet.
    • Tighten the fittings to 15 ft lb (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks
Oct 14, 2010 | Oldsmobile Alero Cars & Trucks
Water pump
NOT HARD BUT YOU HAVE TO DRAIN COOLANT OUT OF SYSTEM.CATCHING IT IN A DRAIN PAN .THE 2.4 ENGINE YOU HAVE TO REMOVE. OXYGEN SENSOR THE EXHAUST MANIFOLD HEAT SHIELD.REMOVE COOLANT INLET HOUSING BOLT THROUGH THE EXHAUST MANIFOLD .REMOVE EXHAUST MANIFOLD BRACE TO MANIFOLD BOLT.REMOVE TO EXHAUST TO PIPE STUDS.REMOVE COOLANT INLET HOUSING TO WATER PUMP COVER BOLT.REMOVE EXHAUST PIPE FROM THE EXHAUST MANIFOLD BY PULLING IT DOWNWARD.REMOVE COOLANT INLET PIPE FROM THE OIL PAN.REMOVE BRAKE VACUUM PIPE FROM THE CAMSHAFT HOUSING.REMOVE EXHAUST MANIFOLD FROM THE CYLINDER HEAD.REMOVE HEATER HOSE FROM THE HEATER OUTLET PIPE.REMOVE THE TIMING CHAIN COVER AND TENSIONER.REMOVE WATER PUMP COVER TO ENGINE BOLTS.REMOVE 3 WATER PUMP TO TIMING CHAIN HOUSING NUTS.REMOVE THE WATER PUMP AND COVER ASSEMBLY.THE 3.1 AND 3.4 ENGINES DRAIN COOLING SYSTEM .REMOVE DRIVE BELT.REMOVE WATERPUMP PULLEY TO REMOVE PULLEY YOU NEED A LONG SKINNEY SCREW DRIVER TO HOLD PULLEY FROM TURNING WHILE YOU REMOVE THE BOLTS.THEN REMOVE WATER PUMP.CLEAN OLD GASKET MATERIAL OFF ENGINE BLOCK WHERE WATER PUMP GOES.BECAREFUL NOT TO SCRATCH PUMP SURFACE ON ENGINE BLOCK.YOU CAN BUY CAN OF GASKET REMOVER AT ANY AUTO PARTS STORES. THEN WHEN YOU PUT ON NEW WATER PUMP.BESURE TO COAT BOTH SIDES OF THE WATER PUMP GASKET WITH GASKET SEALER .BEFORE PUTTING GASKET SEALER ON WATER PUMP GASKET.BESURE TO GET HOLES MATCH UP RIGHT ON WATER PUMP AND GASKET.WHEN YOU GET IN PUMP IN PLACE TORQUE IT AT 89 INCH POUNDS AND PULLEY BOLTS 18 FT LBS.THE 2.4 ENGINE BEST TO HAVE** HAYNES REPAIR MANUAL ** BECAUSE REMOVING THE WATER PUMP YOU ARE DEALING WITH THE TIMING CHAIN AND TENSIONER.YOU NEED ALL THE EXHAUST BOLTS TORQUE SPECS.AND WHEN YOU COMPLETE WATER PUMP FIX.ADD COOLANT.CRANK ENGINE.CHECK FOR LEAKS.BLEED COOLANT SYSTEM.
Jun 14, 2010 | 1999 Pontiac Grand Am GT
Need the step by step instructions and pictures on how to replace an water pump on an 2002 Oldsmobile Alero 2.4L
2.2L Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Disconnect the negative battery cable.
  3. Drain the engine coolant.
  4. Remove or disconnect the following:
    Exhaust manifold, if equipped with n automatic transaxle Right front wheel Splash shield Water pump sprocket access plate from the timing cover
    Fig. Remove the water pump sprocket access plate from the timing cover -2.2L engine
  5. Attach Water Pump Sprocket Holding Tool J 43651to the sprocket using the access plate bolts to secure the tool to the engine front cover.
    Sprocket to water pump bolts Engine block to water pump bolt Engine front cover to water pump bolt Thermostat housing to water pump feed pipe 2 water pump to engine block bolts Water pump
    Fig. Water pump mounting-2.2L engine
To install:
  1. Use a threaded stud in the water pump hub to align the hub to the water pump sprocket.
    Water pump and bolts Thermostat housing to water pump feed pipe Engine front cover bolt and engine block to water pump bolt. Tighten the bolts to 15 ft. lbs. (20 Nm) 2 of the water pump sprocket to water pump bolts
  2. Remove the threaded stud.
    Last water pump sprocket to water pump bolt and tighten the sprocket bolts to 89 inch lbs. (10 Nm).
  3. Remove the tool.
    Water pump sprocket access plate to the timing cover and tighten the bolts to 89 inch lbs. (10 Nm) Splash shield Right front wheel Exhaust manifold, if removed
  4. Fill the cooling system.
  5. Connect the negative battery cable.
2.4L Engine
  3. Drain the cooling system.
    WARNING Do not rotate the flex coupling more than 4 degrees or damage may occur. Oxygen Sensor (O 2 S) electrical connector Exhaust manifold heat shield Coolant inlet housing bolt through the exhaust manifold Exhaust manifold brace-to-manifold bolt Manifold-to-exhaust pipe studs Coolant inlet housing-to-water pump cover bolt Exhaust pipe from the exhaust manifold by pulling it downward Coolant inlet pipe from the oil pan Brake vacuum pipe from the camshaft housing Exhaust manifold from the cylinder head Heater hose from the heater outlet pipe Timing chain cover and tensioner Water pump cover-to-engine bolts 3 water pump-to-timing chain housing nuts Water pump and cover assembly Water pump cover from the pump
    Fig. Exploded view of the water pump mounting-2.4L engine
continue...
Oct 22, 2009 | 2002 Oldsmobile Alero
1.9 dti somkes like hell when running
disconnect the thin plastic pipe that runs from inlet manifold or evan the vac pump through a relay to the unit thats controling the pipe from the exhaust manifold into the inlet manifold .and smoke will vanish
Nov 22, 2008 | Volkswagen Passat Cars & Trucks
Garden Logo
228 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
