I am not having a problem with my portable air conditioner unit but I do have a question about the unit having a heating fan. What would a heating fan be used for in a Air Condtiioning unit with Humidifier?
    Brigadier General:
  • 4,736 Answers
Its for defrosting the unit, if it freezes up.
Posted on Mar 21, 2011
    Problem Solver:
  • 14 Answers
To defrost the heat exchanger in between cooling cycles. As it air conditions, it pulls moisture out of the air, and causes a layer of frost to form on the heat exchanger. Some units just let this frost melt off. But if it doesn't completely melt, it can start to form an unmeltable glacier. Since your unit in a dehumidifier model, it probably relies on the heater fan to ensure that you don't get an ice-up on the exchanger.
Is my portable lg air conditioner suppose to be blowing hot air out of the back
YES
it works the same as any air conditioner where if you go outside and place your hand at the fan then it will be blowing hot air
In the instructions it should say place the rear near an open door or window or use the hoses to move the hot air out of the room
air conditioner units are basic heat transfer units where they take the heat out of the room and transfer it to the outside and in the process remove the moisture from the air in the room which i turn makes it more comfortable
Mar 14, 2016 | LG Heating & Cooling
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Why is my appartment getting cooler ???
An air conditioner really just moves heat from one place to another. Normally there is an inside unit and an outside unit, or in the case of a window unit, half is inside the room and half outside the window. In either case, it takes the heat from in the room and moves it outside. This portable unit apparently takes the heat from one room and dumps it into another. There is no magic heat elimination - it has to go somewhere.
Jul 01, 2014 | Simplicity 6,000 BTU Portable Air...
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Aug 18, 2009 | Maytag Electronic Portable Air Conditioner...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
