Question about Hitachi 42HDS69 42 in. Plasma Television
Looking to use the PIP feature with my 42HDS69 TV. When I access the function, the second screen can only utilize the AIR input. No other inputs are available. I just want to change between the digital stations.
  • Hitachi Master
  • 8,457 Answers
U have cable or satalite service?Yes,this functions,will work correctly.Tv have only free DTV broadcasting air signal only,will not able to watch two air broadcasting channels at the same times.
Posted on Mar 21, 2011
I am trying to run pip with x box in the pip and regular comp on main screen but it dosent work the xbox is hi def cables
What inputs are you actually using? If you use VGA as the main display, the PIP feature will work with DVI, 480i (SD) Component Video, S-Video, or Composite video. If you use DVI for the computer's input to the TV, the Component video PIP doesn't have the 480i limit.
Thus if you have VGA from the computer, Hi-def from the X-box isn't going to work. Note: The component video can not be the main screen with VGA input in PIP.
I hope this helps.
Apr 24, 2010 | Gateway FPD2185W 21 in. LCD Television
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Mar 18, 2009 | LG 32LG30 32 in. LCD HDTV
Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Feb 10, 2009 | Zenith C27V36 27" TV
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
PIP
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
junk@slaing.com
Dec 31, 2007 | Vizio L32 32 in. LCD HDTV
PIP trouble
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Sep 25, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Hitachi 42HDS69 42 in. Plasma Television Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
