Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Lamp need replaced?
Okay,so power light comes on but no sound/screen and then goes back off about 2-3 minutes later?
    Scholar:
  • 146 Answers
If that is what is happening, with no other light coming on, then I would try and unplug the tv from the wall for 30 min. Plug it back in and try turning it on. If this doesn't fix it, you will need to take it to a repair shop.
If the LAMP light goes red then replace the lamp.
Posted on Nov 15, 2008
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Tv restarts while we're watching it
It sounds lamp is weak in tv and need to be replaced.
If lamp has not been replaced in last 2-3 years then replace it to get tv problem fixed.
Thanks.
Jun 07, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My tv screen goes off including sound for about a minute or and then comes back on 10 minutes later it happens again the lamp light does not come on
It is symptom of weak lamp in tv.
Please replace lamp, replacement procedure would be written in user manual and its easy. Buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 22, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony grand wega 55in kdf-55a20
Its most likely an intermittent lamp. The lamp door is located behind the front panel. The front panel can be removed after loosening the two thumb wheels located on either end of the TV in the rear. Observe the light coming from the area around the lamp door. If you see that the light is going out, its the lamp. You can also access the self-diagnosis menu by using the remote control. Start with the TV off. Push the "mute", then the number 5 button, and then the volume down button followed by the power button. When the picture appears, the menu will been visable. If there is a failure with the lamp, or a fan, or many other areas in the TV there will be a number value to the right of the parameter that indicates the number of times the error has occurred.
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
TV turns off/on
remove the bulb,(very easy to do just follow directions in the manual). On the top and bottom of the lamp there is a fine mesh screen. mine was plugged with dust. I used a vaccuum hose to remove the dirt, replaced the lamp and the tv now works.I found this remedy at a site but can't remember where (crs syndrome). saved me a $200 service call.
Jan 26, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
KF 42WE610 turns on for two seconds, then goes black
no, had the same problem. Its the lamp ballast also called the lamp power block. It supplies power to the lamp, any how some repair shop wanted $450 to fix it, so i ordered the part from sony, part #146879816 ($116.25), trust me this is the part I double checked with many different places. Any how fixed it my self took about 15 minutes, just take the back cover off and the part is right there just kind of follow the screws and the 3 wires, super easy job, I suggest you replace the bulb at the same time, dont by a cheap bulb just get it from sony
Nov 06, 2007 | Sony XL-2100U Projector Lamp for...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
