Question about Kenwood KDC-MP738U Car CD / USB/ MP3 Player
My radio face keeps turning off. i think its a connection problem but i'm not sure.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You may have bad solder connections on some surface mount resistors inside of the radio.
Posted on Mar 21, 2011
The face to my 07 expedition's radio is not illuminating when lights are turned on...I have taken the radio apart and have not been able to find a bulb.
I dont think there is a bulb you can change. At the dealer.. thay send the radio out for an exchange radio for any lighting concerns.
Nov 26, 2012 | 2007 Ford Expedition EL XLT
My radio keeps saying "Protect"
First make sure your speakers and speaker wires have not shorts or grounds. If they all check out good try pressing the reset switch (usually a small pencil tip sized indentation on the front of the face or behind the face on the sub panel. If it still reads protect after that, you may have a bad output ic.
May 17, 2011 | Kenwood KDC-MP235 CD Player
I went over a pot hole and my face plate popped off and now it won't stay on what should I do ?
i suggest first reading the directions to make sure you are connecting the face plate correctly. or you could gorilla glue it on just to make sure the connections from the face plate and radio are connected before binding the two
May 05, 2011 | JVC Car Audio & Video
My truck keeps dying and i believe its from the radio cuase when i take the face off to put in my house theres a red light that still blinks so i think its still on.
The blinking red light is to let thieves know the face is not on the radio and is not worth stealing. the blinking red light doesn't draw enough power to drain your battery.
Apr 23, 2011 | Kenwood KDC-MP205 CD Player
How do i get the dash off to pull the old radio out
I'm not totally sure about the La Sabre, but there should be trim screws that hold the Dash face plate in place. There are three on the top portion of the face plate, and I think three on the bottom . The face plate extends from Light switch on left to radio on right. You may have to tilt the steering wheel column down to remove the face plate from around the steering wheel. From what I remember, the only thing that needs to be unplugged from the face plate is the plug for the rear defroster. Also, there are clips that hold the face plate in place. They just push in and out. Once the face plate is off, you can get to the radio mounting screws.
Aug 16, 2009 | 1993 Buick LeSabre
Nokia 5200 - radio not working - connect an enhancement error
I Think there is some problem in Radio settings, so just make sure to reset mobile settings
Jun 17, 2009 | Nokia 5200 Cellular Phone
Loss of memory when remove the face
Your wire connection is incorrect. Make sure that the yellow wire comming out of the radio connects to a yellow wire from the car and that the red one connects to a red one. Also make sure the radio is grounded properly.
Jul 19, 2008 | Panasonic CQ-C1100U CD Player
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
May 16, 2008 | Jeep Radios: Genuine 6 Disc Cd Changer
Adding a remote USB port
I solved my own problem.1 I removed radio1.gif face 2 I removed back cover of radio face to expose USB solder joints.3 I drilled a hole in the back cover of radio face over solder joints 4 I drilled a hole in front cover of radio behind face plate and lined it up with hole in back cover of face plate.5 I cut the male plug off of a USB extension cord and ran it through factory notch on the back of radio,through drilled hole on front panel of radio, thruogh drilled hole on back cover of radio face and soldered wires to back side of USB plug in. Wire colors from top to bottom are Red, White, Green, Black. Solder sheild to any of the three larger solder joints next to these connections. Make sure wires are not touching any other connections. Put radio back together and add screw that locks face to radio. Face can no longer be removed with this wire added. Now I can plug in my 8gb memory stick1.gif,hide it under the dash and have a clean looking installation.
Jan 17, 2008 | Kenwood KDC-MP435U CD Player
Tuning the radio
You have two "hot" wires going to the radio. One is the main B+ power and the other is for the "mem" function which keeps clock time and radio station presets in memory. Make sure that you have 12 volts to the memory wire (blown fuse?) If you do then you may have a problem that requires a trip to your local repair guy. Do you loose your preset stations when you turn off your car and leave the face in place (wait several minutes before turning car ignition back on)? If that is so, then you most likley don't have B+ to your memory wire. Good luck.
Aug 16, 2007 | Sony CDX-L480X CD Player
Kenwood KDC-MP738U Car CD / USB/ MP3 Player Logo
78 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
