Question about Fisher and Paykel RH361SS Kitchen Hood
Fan will not come on. Problem started a few weeks ago - just clicks/ticks when any setting is selected. Lights were still working for awhile but then seemed to burn out all of a sudden, all three bulbs within a day or two of each other. LEDs on control panel still flicker on when a fan option is selected but immediately go out as the fan will not turn on. Verified that power at the outlet is fine. Hood is only a few years old so at a loss.
2 Suggested Answers
  • 11800 Answers
SOURCE: I have an RH361 hood.
In this unit the fan motor and the lights are electronically controlled. Since all of them failed it means that the control board has failed and it will have to be replaced.
You can find one here, including a diagram
http://www.searspartsdirect.com/partsdirect/part-model/Fisherpaykel-Parts/Range-hood-Parts/Model-RH361/3068/0122400
Posted on Mar 22, 2011
Intermittent management light comes on at start up.
try having a scan toll read the faults then reset the ECM program
Mar 28, 2017 | Cars & Trucks
My dash is ticking and the dome and door lights are flashing; what could be wrong?
the ticking noise will be from a faulty relay and will not be covered by codes. At best you will have to locate the clicking relay and replace it . IT will have something to do with the interior lights ,door switches and may be the light control module.
Aug 31, 2014 | 1998 Buick LeSabre
2008 Highlander will not start. Makes a ticking noise when pressing keyless start
Immobiliser ?
Try this thread it may help - http://www.helpowl.com/a/Toyota/2008-Highlander/Research/5115?search=2008%20toyota%20highlander%20vsc%20check%20engine%20light
Mar 19, 2014 | 2005 Toyota Highlander
Hello, Two weeks ago I purchased a Maxell 4 GB memory stick so i can save all my data in it. However, when i add a photo it says memory full or that i need more space in it and i only added one photo.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Jun 21, 2011 | Computers & Internet
My speakers phillips ambx premium kit was recently bought and all was well, with everything working fine but a few days ago the lights have stopped working due to not being registered on the ambx...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 11, 2011 | Philips SGC5103BD 2.1 Speakers
Bought the car a few weeks ago. they said i would need a new battery. Put the new battery in it. For a couple weeks it started up fine then one day it the battery was dead. my charging system checks out...
se connection directly to starter if rusty doubel d it , replace nit "carefully acter disconnectiong batt, make sure radios not "coded " if it is see if u have code or use jumper wire to keep memory on batt
Apr 01, 2011 | 1994 Cadillac DeVille
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Starter clicks and when i mees with it for awhile it will start will start up fine for the rest of the day but when morning comes it happens all over again i just put in a new starter a few months ago and...
check to make sure the starter has not become loose and/or add any shims that may have come with it. Also check your wiring for loose connections.
Jan 10, 2010 | 1997 Jeep Tj
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Fisher and Paykel RH361SS Kitchen Hood Logo
26 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
vince
Beamvacman
Level 1 Expert
Peter
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
