Question about Dometic RM2652 Refrigerator
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on gas, nothing on AC.
Just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Posted on Apr 29, 2014
  • Dale Rivenbark
    Dale Rivenbark Apr 29, 2014
    just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
  • 68 Answers
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Posted on Mar 19, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
SOURCE: How many amps does a unit like this use?
According to the label (inside the hinge of the main door), it's 2.7 amps when running on 110 volts. It shows blank for running on 12 volts. However, with the anti-humidity switch on, it can use enough current to drain your battery. I was concerned about the battery draw when running the fridge on 12 volts, because the dealer told me it defrosts itself every 72 hours. Something has to control this, and probably uses some power.
Posted on Jul 25, 2009
SOURCE: RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Posted on Apr 10, 2010
  • 44 Answers
SOURCE: Dometic 2652 recall repair and now converter heats
you will need to get an adaptor for your plug as the electric volts in mexico are different than US.You can go to hardware store and they will tell you wich one
Posted on Apr 11, 2010
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Apr 04, 2010 | Dometic RM2652 Refrigerator
Feb 03, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
404 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
