Question about Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong
When flushed, my toilet fills with water and has to be manually bucketed out water leaks from the stopper on the right hand side of the turbo flush box... The macerator does not seem to be working and is not making any any noise at all
    Problem Solver:
  • 14 Answers
You need a plumber with experience with this type of toilet
Posted on Mar 21, 2011
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
How do you stop a power flush toilet from constantly running?
You'll have to see if the water is leaking past the flush stopper or into the overflow tube. The tube is the little pipe where water drains if the tank is filled too high. The flush stopper is a rubber flapper mounted on the bottom of the overflow tube. If water is running into the tube, then the flush valve may be stuck, so shake it up and down (gently) and hopefully it will be freed. If water is not running into the tube, then reach down and try to seat the flapper stopper to see if something was lodged there to keep it from seating all the way. Would be a simple fix either way.
Dec 08, 2014 | Home
When flushingtoilet water backs up inshower
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
Apr 13, 2013 | Motorcycles
How can i make the toilet flush by adding water to the tank
pour a bucket of water right where you go to restroom unless its stopped up it will flush
Jul 27, 2012 | Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
Toilet won't flush - water drains very slowly
YOU COULD HAVE A BLOCKAGE IN YOURE LINE OR IF YOU ARE LUCKY YOU JUST NEED TO ADJUST THE CHAIN THAT CONCTS THE Handle to RUBBER STOPPER IN THE BACK OF THE TOILET THIS WATER IS CLEAN AND YOU CAN PUT YOUR HAND IN THE BACK PART OF THE TOILET WITH NO WORRIES JUST TAKE OFF THE LID AND FLUSH IT OBSERVE THE RUBBER STOPPER IN THE BACK OF THE TOILET IS IT COMING ALL THE WAY OUT
Jan 19, 2010 | Toto Aquia II Dual Flush Toilet
Open Questions:
Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong Logo
225 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
