Question about Kenmore Dryers
I have a Sears Kenmore Gas Dryer Model Number 110 72612101 Serial Number MM2606191 that appears to be over-heating. All my clothes come out smelling like burnt rubber and/or dry cleaning compound. If I put clothes in the dryer and button it up, ready to go the exhaust vent pipe gets so hot you can't touch it for any length of time. If I pull the lint filter or open the door and over-ride the saftey switch the dryer cools down but the smell remains. I think that it's the thermostat and what is actually turning the heat off and on is the Thermal cut-off. I'm looking for some type of verification before I rip into her for part numbers. Any ideas of possiblities that I haven't considered? Thanks so much!! DaN
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
I suspect the vent is the issue with your dryer. It sounds like the air is not moving to the outside well and is keeping the interior too hot. The filter housing may also be plugged. Make sure the vent is clear all the way to the outside. Be certain that the hose is not kinked or crushed behind the dryer and is as short as possible. You may change the operating thermostat as well.
Kelly
Posted on Mar 21, 2011
How easy to replace motor Kenmore kenmore 417.92042101?
Replacing a motor is fairly easy, but they are very expensive. It is often a better bet to just purchase a new machine, because whilst you have the machine that far stripped down, you might as well replace the rear bearing and the front drum slides.
Your motor is $87, so not a bad price. And as yours is a gas drier, it is probably a good bet to just replace the motor.
Parts
Kenmore Dryer Model 417 92042101 41792042101 417 92042101 Parts
KENMORE DRYER Parts ' Model 41792042101 ' Sears PartsDirect
https://www.searspartsdirect.com > Model Search Results for "41792042101"
Shop for KENMORE DRYER repair parts for model 41792042101 at Sears PartsDirect. Find parts, manuals & diagrams for any KENMORE DRYER repair project.
How to Replace a Kenmore Gas Dryer Drive Motor - YouTube
? 4:24
https://www.youtube.com/watch?v=vunod36mWGE
Jan 11, 2015 - Uploaded by Sears PartsDirect
Sears PartsDirect. ... This video from Sears PartsDirect shows how to replace a broken drive motor in some ...
Jan 13, 2018 | Cars & Trucks
We have a sears dry model no. 1107481220 and the dryer is not drying the clothes.
Ok, first does the heat come on at all, if not,, make sure the gas if coming on, if it is, you need to check the thermostats, If its not, you need to replace the coils located on the gas valve itself it looks like this http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/694540/0026/110/Model-11074812200/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11074812200&subCompDesc=Burner%20assembly&brandDesc=KENMORE&modelDesc=GAS-DRYER&blt=11 that is the main one, and you have a second one too that should be replaced at the same time, it has 3 terminals, for a diagram of the burner assembly click on this http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11074812200/0582/0151200?searchedModel=1107481220&blt=
Jul 09, 2011 | Kenmore 74892 Gas Dryer
Hello; I have a sears kenmors electric dryer that does not dry my cloth the first cycle . I checked the vent and cleaned out the complete dryer from the air inlet through the exhaust and the fan inside...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 25, 2010 | Kenmore Dryers
I get black streaks like the rest of you.. I
it's not the drum,it's the felt pieces that the drum rides on, there is felt on the back of drum and theres a felt piece on the front bulkhead, they could be worn leaving a space letting the clothing slip through hitting the black rollers or something is falling through the space hitting the clothes next time send the model number so i can look up your dryer,the model number is around the opening where you put the clothes into the dryer,open the door and look around the opening and you'll see a tag with model and serial number
Jan 22, 2010 | Kenmore 73952 Gas Dryer
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
No heat
Sears Kenmore electric dryer model #110.96320100 will not get hot.
Nov 12, 2008 | Kenmore 63942 Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Aug 29, 2008 | Bosch Nexxt WTMC3521UC Gas Dryer
I need a schematic for Kenmore dryer number 417.93052201
sears.com enter your model theyll have a wiring diagram there for you
Mar 06, 2008 | Kenmore 74602 Gas Dryer
My clothes smell burnt
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Nov 28, 2007 | Kenmore 74832 Gas Dryer
Dryers Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
