Hi, my MXL 1006 mic dose not woek properly. when I tap on it it work but as soon as I move it it stop working. now it do not work at all. the mic cable is ok. John
Check ALL your mic cables
Posted on Apr 13, 2011
    Sergeant:
  • 296 Answers
Short in the cable inside the mic.
Posted on Mar 21, 2011
My marshall MXL V67 MIC doesn`t work
If this is a condenser micrphone it will require Phantom Power from the mixer you are trying to use it with. If Phantom Power is provided, check the cable to ensure proper wiring.
Jul 27, 2014 | MXL Audio Players & Recorders
Does a MXL 990 microphone work without an inbox ?
You must connect the mic to a mixing board or similar unit which will provide Phantom Power to the mic for it to work.
May 29, 2014 | MXL 990s Professional Microphone
Does an MXL 990 microphone only work with an inbox?
By "inbox" do you mean a transformer that powers it?
Condenser mics need 48 volts (phantom power) to run, so you normally switch the phantom power button on for the channel you have the condensor mic. plugged into.
Mxl 770 won't pick up sound
Condenser microphones require Phantom Power from and external source, such as a good mixer. Make sure your mixer has it available and it is turned on. Then make sure you have a good and properly wired mic cable. If these suggestions do not help I would contact the manufaturer or retailer where the mic was purchased. Take the mic to a music store and ask yhem to hook it up to see if it will work.
Dec 03, 2013 | MXL 770 Professional Microphone
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
I've had a Marshall MXL 2001 mic for seven or eight years, and it's worked without a problem. Yesterday, it stopped working. I opened it and don't see any loose wires. Where should I take it for repairs?
mics are very delicate . a lot bundled into a small area. If you are handy..take it apart. All you may be able to do is check for loose solder joints..mics are dropped, moved a lot so they go through a lot of physical stress. My last mic repair ended up being a bunch of loose solder connections. if not..if its of value to you..send it in. Trace Electronicss..Canada.
May 06, 2010 | Marshall MXL 2001-P Professional...
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
Pls help
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
Nov 19, 2008 | MXL 990s Professional Microphone
Stopped Working
cables,phantom or connectors
Aug 20, 2007 | Marshall MXL-V69-MEDT Microphone
47 people viewed this question
 Grubhead
Grubhead
